Question about Kicker Solo-Baric L5 Car Subwoofer
SOLO BARIC L7 15 SUB
I BOUGHT TWO 15 SUB'S FROM A GUY, AND GOT HOME AND THEY WOULDN'T WORK, I KNOW IT WASNT THE AMP OR ANYTHING ELSE, SO IM GUESSING THAT THEY ARE BLOWED, IS IT POSSIBLE TO GET THEM REPAIRED?????????????0
No as the the voice coil has been burnt out there is no way u can repair them. didnt you test the subs out before you bought them? remember if u buy used den allways check em out!
Posted on Oct 27, 2008
Sub and amp cutout
i guess you need to check the watts of your amp and sub, maybe it not match the power of both item.
Jul 27, 2012 | Legacy Car Audio & Video
I have one solo baric hooked up in a 4 ohm series to a 1000 watt kenwood amp that I've tried hooked up normal and bridged at 4 ohm. When I turn it up the sub cuts out. I've looked up a bunch of...
hello, first i would find out what ohm your sub is cause you may think your setting it up for 4 ohm you may be going 2 ohm or 8 ohm. here is the link to for wiring solo baric. http://kicker.com/wiring_diagrams
Aug 24, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
S10L7 displacement
Recommended Sealed Enclosures – Moderate Efficiency
  • 0.66 cu ft is the displacement of the sub
  • S10L7 .66 cu.ft. Power Handling = 600W 1.0 cu.ft. Power Handling =600W
  • 18.69 l 28.32 l
The following page shows examples of the minimum enclosure sizes for each of the Solo- Baric L7s. Panel dimensions assume 3/4" wood thickness. 5 Panel dimensions for minimum recommended enclosures: Model Volume (cu.ft.) Panel A Panel B Panel C S8L7 0.33 10"x10" 10"x8" 8"X8.5" S10L7 0.66 12"x12" 12"x10.5" 10.5"x10.5" S12L7 0.88 13"x13" 13"x11.5" 11.5"x11.5" S15L7 1.5 16.5"x16.5" 16.5"x11.5" 15"x11.5"
Jun 03, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How to bridge my solar baric subwoofer
is it for house or car, do you have it wired to a amp.
Dec 12, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have my l7 solo baric on series mode they sund
Hello rigo11785,
The MTX Thunder 1501D is stable at 1ohm and outputs 1,500 watts RMS into that impedance. An L7 with 2ohm DVC's would present a 1ohm load if wired in parallel and would allow the amp to produce more power than into the 4ohm series load. The problem is that the L7's maximum power handling rating is only 1,000 watts RMS, so if you wire the coils in parallel, you'll very likely overdrive the sub and perhaps damage it. Now, if you bought another L7 and ran the voice coils in series and the subs in parallel, that would be a 2ohm load and well within their power handling capability.
With that amp and sub, I'd recommend leaving the voice coils in series.
Hope this helps.
Jul 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Whats the best settings for a 2 ohm solo baric 15
settings are all about what amp and box u got. tell what setting your talking about.
Apr 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L5 Car Subwoofer Logo
130 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
