Ilost the instruction sheet that came with the router. I moved to a new location and had to break down the computer system. I'm nt sure how the cables go
  • 52 Answers
Dont think with the cables, just match the slots and cable, any cables comes with unique slots.
Posted on Jul 12, 2008
I moved and can not connect at my new address
Hello
Kind of lacking details: Computer? mobile? Ethernet? Wireless? Ethernet: Check all the cables (unplug and reinsert), power on router and then the computer, which should locate it automatically. Be sure that the wires aren't kinked anywhere and check your website (provider) to see if there are any issues. There will be a section to troubleshoot your connection as well - did you let them know that you moved?
Wireless: Be sure to let your device locate the Wireless networks available and then select the one that has the same name as your router and enter the password (also on router). There might be additional settings like security (Wep2-personal and encryption methods (AES)), check on the website linked to your provider account (IP address) what the settings should be; more details about this will also be available on the website.
Specific steps will also depend on your operating system: check Device Manager and Network adapters to see if they are present, need updating or are displaying a problem.
Move your device closer to the router to determine that the distance between them or walls, other devices etc. aren't interfering.
Aug 11, 2017 | Computers & Internet
Moved router to another location would not connect.
Who is your Internet service provider at new location?
I think you should try to reset and reconfigure the router from the scratch.
Connect the computer directly to the modem and make sure that your Internet modem is working properly.
Connect the modem and computer to the router. Open the setup page of the router and change the settings of the router.
You can try this Linksys Router Setup website and I think it will help you.
May 27, 2012 | Linksys Wireless-G WRT54G Router
Ilost my cd of linksys how to configure
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 25, 2010 | Cisco Linksys Wirelessn Router Black...
Di-604 Dlink, I moved and when I hook up to my new house location the dlink I don't get connected to the internet.
through the modem.
modem
Then you need to connect the computer to the
Feb 03, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
We recently moved and set up the computer. I have
Moving means that you have to setup the router again. The WEP key has to be setup again. Your old settings were for old location. Could be same settings, but they have to be setup again.
Nov 08, 2009 | NetGear WGT624 Wireless Router
Weak signal
Go to your basic setup and change IP. Your default is 192.168.1.1 you can change it to a higher number
(ie:192.168.1.4) Also make sure and set up security.
If you leave it open others can use your connection and slow you down.
Oct 21, 2009 | Linksys Wireless-G WRT54G Router
"Connection failed" -- USB connection
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
"Camera not connected" -- USB connection
The "Camera not connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me, 2000 or XP to use a USB connection. Your computer must also have the appropriate USB connectors. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
