Question about Garmin GPS
Garmin c330 fell and the outside glass to screen is not broken but the layer under it is shattered. it powers up but touch screen does not respond. is this something i can fix myself?
  • Anonymous Dec 06, 2008
    Garmin eTrex Vista HCX
    Fell and cracked the glass screen and the lcd display underneath, still powers up but screen has totaly had it.
  • Garmin Master
  • 2,130 Answers
No, you will need to replace the LCD screen. Unfortunately, Garmin will charge you almost the price of a new unit for fixing it. You might be able to find a used unit on eBay that is dead but has a working display and swap the displays but it requires some electrical & mechanical knowledge.
If I can find a display, I can put it in for you for a reasonable price.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Jul 12, 2008
Broken glass on touch screen display for epson workforce 845
The touchscreen is sold as one part, you can't buy or replace just the glass. There is a capacitive layer glued to the glass that is probably damaged.
Feb 03, 2013 | Epson Office Equipment & Supplies
Broken screen
yes, you can replace the touchscreen glass
Oct 06, 2009 | Posiflex Jiva 5800 All-In-One...
Garmin streetpilot c330 no sound Everything works but no sound. i tryed the volume on the right side but still no sound. what could be the probs? Guarantee expired. How much could it cost to fix? Thanks!
It's the volume pot having a broken solder connection. Disassemble & touch the connection w/a hot pencil iron, but you'll need to do this under a magnifying glass, because of the size of the contacts.
Jul 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin 2720 touchscreen won't work, must use remote control.
I'll start with a comment I made on another post:
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. Actually the real last resort is to have Garmin fix it for a flat $250. Good luck.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin c330 cracked screen
You can buy a new C330 now for $125 - $175. It would probably cost that much to repair the old one, I would replace it.
Jul 07, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330 - screen problem
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site: Question:  The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer: To recalibrate the touch screen:
  1. Turn the unit off.
  2. With the unit off, touch and hold the Power button for 30 - 40 seconds.
  3. Follow the instructions on the screen.
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Try to calibrate the touch screen. Push and hold the power button on until you see a white dot on the screen. This is the calibration mode. Touch the dot and another dot will apppear, now touch this dot again, keep doing this until the unit reboot.
If you touch the 1st dot and nothing happens then the digitizer on the LCD is dead. If the unit is still under warranty, get a RMA and return it to Garmin.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Sep 30, 2007 | Garmin StreetPilot 2720 GPS Receiver
GPS Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
