Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
GE side by side gss25lsmf stopped working
I have a side by side refrigerator that was working fine for 5 years. Today i noticed water in the freezer but there was some ice in the ice maker so i emptied the refrigerator.
I noticed that the motor was working overtime without cooling. a few hours later the motor wont even start. The lights and buttons( ice, water, door lock) on the front work just fine.
Can someone suggest troubleshooting steps?
Thank you very much in advance for your help
  • Ashin Jul 12, 2008
    Thank you very much for the answer.
    Overnight i observed that the fan was working very hard but the refrigerator was not getting cooled.
    Are there any ways i can check or replace the compressor myself?
    i am looking for professionals but just in case its a easy task.
    Ashvin
  • 481 Answers
It could be a number of things but none of them can be fixed without professional help.
things it could be:
  • bad compressor
  • blockage in the freon line
  • small possibility of a freon leak
Posted on Jul 12, 2008
  • Mike Durland
    Mike Durland Jul 12, 2008
    changing the compressor is not easy. it requires a freon evacuation and recovery pumps and tanks, decent brazing skills, freon scale, access to the type of freon required (some require a license to purchase) just to get started. also it is an expensive job $300-$500+
I have a Frigidaire refrigerator . Model? But though it's about 8 to 10 years old, it wasn't used for about 4-5 years. It has been fine for the last 5 years that I have used it, it has been working fine....
Joann I would suggest you look and change your water filter. It should be located in the refrigerator side on top. Just twist it off, take it to Lows' and find a new one.
Jul 23, 2014 | Refrigerators
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge ice maker stoped working
Check out the tray heating element that is designed to melt the ice slightly so it can be scooped out into the waiting tray.
If there is no water or ice in the tray, then check out the solenoid that allows water into the system.
Apr 19, 2017 | GE LightTouch GSC23LSRSS Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Water in door stopped dispensing
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
198 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
