Question about Connex Radio Communications
Connex coyote hunter will not transmitt
I have a 4ft fire stick ant. the brass screw came out of the top of it and now the radio will recieve but will not trans. ive tried diff. micks,antanns ,cable,im not sure whats up with it any ideas
  • 90 Answers
It's possible (but not very likely) that the final amplifier blew out after you lost the tip of the FireStik antenna.
Posted on Jul 20, 2008
Just bought a connex coyote hunter.the antenna i have is for cb i know that for 10 meter radios you have to have a antenna thats tuned.on cb band shouldn't i be able to hear On cb band? With cb ant?
The antennae has to be tuned for the radio not for the band you are listening to. If is a 10 metre band, so you need a 10 metre antennae which enables you to listen to both bands, but looking at the jpg of the radio it gives bands A, B, C, and D, nothing about CB radio itself, but the option of AM and FM radio.. Using the wrong antennae could damage it.
you could get some help here
http://www.cbradiotalk.com/viewtopic.php?f=9&t=29531
specs here
Picture and Specifications of the Connex Connex Hunter Mobile Export Radio
Dec 12, 2015 | Connex Radio Communications
Need operating manual for connex deer hunter
contact Connex ,see if they have one they can send to you . Maybe even a photocopy.
Nov 24, 2013 | Cobra 29 LTD CB Radio
My cobra 29 ltd is in a ford truck with a over head camper. i put a magnet mounted wilson 1000 watt ant (4ft.) on top of the cab. I cannot get any squelch to work I did a radio check i believe i was heard...
Assuming you don't have the manual,basic controls for receive are to make sure the switch next to the meter is set to s/rf,switch for cb/pa is set cb,knob for rf gain is at max, squelch knob is fully counterclockwise..squelch can be adjusted if ya don't want to hear static but will start cutting out weaker signals.If none of the above works,try plugging in an external speaker to the jack on the back of the radio,if ya still don't hear anything,check that antenna coax is screwed in tightly in back of the radio.Next step after all that would be the microphone,is the stock mic,power mic..if it is the original stock mic that has not been rewired in any,then I would suggest taking radio to qualified cb repair shop,bring mic with you to shop so they can check it too,in fact I would bring the truck also so they can check antenna and adjust it if needed...Good luck
Sep 04, 2011 | Cobra 29 LTD CB Radio
Como combertir el coyote hunter a 11 metros
  1. Quite la cubierta superior de la unidad y busque las resistencias en la parte inferior de la tarjeta principal
  2. Desoldar, y saque a los que es.
  • Si usted tiene el modelo más nuevo con los Mosfet en que el uso esta conversión
  1. Quite la cubierta superior de la unidad y busque la fila de 15 pines en la parte delantera de la unidad. Desoldar el cable de tiro corto desde el 7. clavijas a los pines 11 y 12 (conectados entre si).
  2. Desoldar el puente de soldadura cortocircuito de los pines 11 y 12 de modo que son pernos independientes sin relacion entre ellos
Un cordial saludo, Tony
Apr 26, 2011 | Connex 3300 240-Channels Base CB Radio
Connex 3300 HP won't change channels when you turn ch. selector stays on same channel ch. 32.
There is a board in the CB called a PCB board. If you open your radio it is a little circuit board. Held onto the side of the radio by a screw and has two or three connectors leading to the board. Replace that little board and your radio will be good as new. I have seen radios come in my shop many times and this is the fix. What that board does is send a signal to the crystals to start mixing a frequency. When it goes out it just sticks where it is at. Here is a link to a place that can take care of you. http://www.hyelectronics.com/default.asp You tell them you need the little PCB board for a Connex 3300 inside the radio. Might be $35 or so.
Mar 14, 2011 | Connex 3300 240-Channels Base CB Radio
My Connex 3300 the Recieve is going out I can here will close but thats it.. Antenna, Coax, SWR's are fine..... Could it be the recieveing ship in it going out or what???
Hi, my name is John. Welcome to FixYa. Turn your RF GAIN to MAX. and SQUELCH to MAX. If you need further, let me know. Thanks for choosing FixYa.....John
Nov 17, 2010 | Connex 3300 240-Channels Base CB Radio
No transmitt
if you'd like call me 904-845-3847 anytime on the week day. mel
Jan 06, 2010 | Connex 3300 240-Channels Base CB Radio
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
153 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
