Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca projection tv
Has blue looking ink spot in middle of screen
    Genius:
  • 1,030 Answers
Ok dont shoot the messanger. this is an indication that there is a burn in crt... cost to replace a crt at our shop about 400 to 500 the tube is about 250 and the labor is rather intensive. I did one yesterday. takes me a few hours to do and i do these every week
Posted on Sep 10, 2008
Black spot in the middle of the screen looks like it has a burned spot
Yes if it uses 3 picture tubes one is burnt dead center--cover the lens one at a time to see which is causing this--permanent damage caused by a arc.
If a newer set you have a display unit with a dead pixel.
Mar 31, 2012 | RCA Televison & Video
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
46" blurred screen and middle of screen is beveled
Yes,Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 19, 2010 | RCA P46924 46" Rear Projection Television
DARKE SPOT IN THE MIDDLE OF THE TV. Looks like a shadow. You can see it really good on light blue and with colors.
Sounds like a burnt blue CRT phosphor.-- Can't reproduce blue at that spot. It would need a new CRT.
Feb 27, 2010 | Toshiba 65H82 65" Rear Projection...
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
The screen on my hitachi dlp tv is running/bleeding blue?
blue specs on the middle of the screen looks like a shot gun pattern just replaced the lamp and noticed these spots?? source??
Aug 12, 2009 | Televison & Video
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Big yellow spot in the middle of the screen
the lcd panel for the blue is bad normally you would have to replace the engine but i know a place where you can get it rebuilted for a price cheaper than the engine go to
N-home tvservice.com for some answers
Mar 02, 2009 | Hitachi 55VS69 55" Projection HDTV
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
