Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Ice machine quit making ice
The ice machine quit making ice but the water works
  • 481 Answers
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
Why isn't my U-Line 3018CLR making ice?
Isn't it obvious the compressor isn't running to freeze the water? Make sure the thermostat is working.
Jul 17, 2014 | ULINE U Line 3000 Series 3018CLRS41 20"...
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Sep 17, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
460 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
