Question about Canon Cameras
I just bought a Canon d750. When I went to install the software it told me that the screen resolution to execute digital camera disk is not suffcient. I'm running Windows XP, and there shouldn't be a problem.
  • sue camera Jul 12, 2008
    I just check my screen setting and they're set as low as they can go.
    Genius:
  • 1,689 Answers
The operating system is not relevent to the screen resolution. This can be set from very low to the maximum that the monitor and display card combination can handle.
If you cannot achieve the proper resolution on your computer, it is possible that the display card and monitor combination may be not up to date to work with the camera software.
You have to make sure that the screen resolution is set to the minimum setting as recomended by the manufacture.
You can find the settings in the screen settings properties. Refer to the installation instructions for details.
Jerry G.
Posted on Jul 12, 2008
Trying to install software for Canon Powershot A640 on a Acer Aspire One Netbook. Receive error message "The screen resolution to execute Digital Camera Solution Disk is not sufficient."
Skip the installing of any software, unless you like the Canon editing or viewing software, if that is on the cd.
Get a card reader for this machine, and skip any drivers whatsoever.
By using a card reader/writer it is not necessary to get any software or drivers on your machine from Canon. The card reader will read as another drive.
Apr 12, 2010 | Canon PowerShot SD1000 Digital Camera
While trying to install Canon Camera software, I'm getting a message that says ''screen resolution to execute digital camera solution disk is not sufficient.
Select the "Start" menu in the lower left corner of your computer monitor screen. Select "Control Panel", then double-click on "Display".
Click on the upper "Settings" tab, then move the slider bar to the right, to at least 1024 x 768 pixel. Then hit Apply or OK. This will increase the screen resolution of your computer monitor so that it will be compatible with the Canon software.
Oct 15, 2009 | Canon Cameras
Intalling camera software.
Greetings Shayy,
Generally screen resolution refers to your computers resolution which is controlled via the control panel of your computer. I would try fiddling with other screen resolutions to see if this helps. This will cause items on your computer to either be larger or smaller than you are used to, but you might find you like it better.
You would go to control panel>display>settings, to adjust this.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon powershot sd850 is digital elph
Hi
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Thomas
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
