I have an Element LCD tv which has lost 1/2 of the picture and is filled with vertical stripes of black and white instead. The Model # is FLX3220 F A It was manufactured in Nov. 2007 and was working for 4 mounth when the problem started. What is the solution please. Thank you, Maxim
  • 2,427 Answers
Well to begin with the brpblem sounds like the vertical controll circuit
The repairs can be a ssimple as a cracked solder to filerts or as complicated as changing the entire mainboard.
in any case i would recommend you taking this in to a service center cause
1.) it contains high voltage which can hurt or kill you
2.) replacement parts will be ceaper
3.) theuy usually fix any other problems it might have
If you have experience and wish to attempt repair your self i'd suggest getting the service manual
http://www.eserviceinfo.com/most_popular/list_17400.html
Posted on Jul 12, 2008
  • Rishi Roshan Ali Jul 12, 2008
    Hey did you get down the service manual, or have you decided if you wish to fix it your self or get a certified technician 's assistance ?
    Genius:
  • 2,035 Answers
This could the problem with the on board capacitor , you can please unplug the all cables for 30 min and then redo all the cable , if this does not solve you need to give the TV to company for service as if still under warranty...
  • Anand Kumar
    Anand Kumar Jul 12, 2008
    If the TV is still under warranty please give it for service to TV company,
    If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
    http://servicemanuals.vstore.ca/
I need the screen for the element flx3220
Tv LCD Screen panel are cost the same as a new tv,bacause the picture screen panel are 90% importmant to the tv.Tries websites like Shopjimmy.com,Ebay.com might have refurbish tv LCD screen panel for sale.
Mar 14, 2011 | Element Electronics FLX3711B 37 in. LCD TV
TV picture not available.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 21, 2010 | Vizio L37 Television
Sony bravia KDL-40V4100 audio and picture cycling on and off
I'd say about the blinking to a black screen would be your cable provider. As for the stripes that means that your board panels can be going bad, you can try updating the firmware of the TV to help but if that doesn't work you're getting very close to full failure on the TV.
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
1998 TV worth repairing?
sound like a vertical collaspe vertical chip...might be more..the fact you still have sound is good.. not all is lost. but technician will have to determine if further damage has occured
Dec 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
