Question about Amana AFD2535DES French Door Refrigerator
Door Pops Open
The left door pops open whenever I close the right door. Does not seem to "stick" tightly. Everything inside is in order and I thing the gaskets are ok. I'm not sure what to look for to correct this problem.
  • rmgrem Oct 01, 2008
    I have the right door popping open. When the right door is closed and the left door is being closed it forces the right door open. It (right door) doesn't seem to 'stick' on the top and bottom like it used to, like the gasket magnets are week. This just started this about 2 weeks ago. The repairman from the dealership said they all do it and I would just have to close the left door first so as to not make the right door pop open.
  • ras4 Jan 11, 2009
    We have the same problem. The fridge is about 3 years old and the right door pops open when the left door is shut. The problem is getting worse. Door seals are in good shape.
  • 481 Answers
Check the alignment of the doors. their is an adjustment on the top hinge. also the hinges have washers on them that you can adjust the door up and down by moving washers to the hinge under or over the door.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
My freezer door used to **** shut now it easily pops open
What you are talking about sounds like the magnets in the door seal are weak.
Mar 10, 2014 | Frigidaire Freezers
Freezer Door
There is usually some adjustment on the hinges. Your is termed buttbound, the door at the hinges is too close so it makes the door pop open. Take everything out of the inside door shelves if there are any. Slacken the mounting screws a little and pull the door away from the frame, make sure it sites square and tight, and then tighten up the mounting screws. With a freezer, i would also suggest fully defrosting it first.
Mar 15, 2017 | Refrigerators
Freezer door opens when fridge door is closed
that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
May 01, 2012 | Maytag Refrigerators
When I close the refrigerator door, the door will pop ajar unless I contine to push it for a second. The seal is in good condition. It feels like there is air pushing the door open. I have washed the...
raise the front legs and get some heavy stuff on the door shelves,also wah around the area where the gasket closes onto the frame,there are magnets in the gasket,also check to make sure nothing is hitting the door from the inside,when food is jammed in or the draw is sticking out to far and the door hits it it doesn't seal good and pops open.hope this helps
Feb 24, 2011 | KitchenAid (KSRD22FKST) Side by Side...
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Dec 24, 2010 | LG Refrigerators
Left door pops open when right door is closed Also
its a very airtight unit so sometimes the doors popping open when another is closed sort of briskly is normal, or the door has gotten tweaked/bent so its magnetic gasket is not making really good, firm contact with the frame to hold it shut..
the water dripping is (if memory serves me correct) the condensate drain for the unit was prone to sometimes getting clogged, or the pan leaking. you may be able to get a ladder and climb up to the cooling box and see where the water is leaking from and remedy fairly easily.
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | True TM-52 Commercial Refrigerator
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Right side door pops open when left door is closed
Is this a new unit? This is caused by air rushing into the other compartment through a damper control. Most mfr's. install an air check valve at the bottom of both doors that will pop up to let external in, thus alleviating door blow out.
Apply a food grade silicone to the face of the door seals to add tackiness to to the surface. Follow link to purchase.
https://www.repairclinic.com/PartDetail/Silicone-Lubricant/WP99003172/1074750. A suitable substitute would be a little Vaseline.
Oct 11, 2017 | KitchenAid Architect KBFA25ERSS Stainless...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
254 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
