Question about Sharp AR-407 Copier
Code H5-01 indicated from the screen
I like to know the simulation mode, code to clear this error.
I checked out the fixing unit heater are all fine.
thank you..
    New Friend:
  • 8 Answers
H5-01 Exit sensor problem try to reset with simulation mode Press "Program" Press "Interrrupt: Press "Clear" Press "Interrupt" enter 1 & 4 then Press "Start"
Posted on Jul 12, 2008
How do clear H4 error code on Sharp Copier arm256
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Aug 02, 2015 | Sharp Office Equipment & Supplies
H-400 error on Sharp 165
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
May 29, 2015 | Sharp Office Equipment & Supplies
HOW DO I RESOLVE H - 4 ERROR ON MY AR-5320E SHARP PHOTOCOPYING MACHINE?
OR
Apr 30, 2015 | Sharp Office Equipment & Supplies
How can i clear H 4 error code on my sharp AR-153E coppier. your help please.
OR
Mar 20, 2015 | Sharp Office Equipment & Supplies
Error h4 on sharp at m318 copier
OR
Mar 16, 2015 | Sharp Office Equipment & Supplies
I have a sharp AR M256 we were getting an error toner replenishment in progress. CAll FOR SERVICE. CODE H4-21
sir
OR
Mar 09, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
HOW DO I FIX ERROR MESSAGE H3-00 ON MY MX M753N
OR
Feb 25, 2015 | Sharp Mx-M753n mx-M753n
Sharp mxm 700 u error code H4-00.what solution that one?
OR
Feb 20, 2015 | Sharp Office Equipment & Supplies
Error h4-00 code on AR- 5127. please what can i do to reset it. Thanks. It also says call for service even though the machine is new.
this error occures if:
The setup temperature (about 90°C) is not reached within the specified time (about 17sec) from turning on the power.
When the temperature of main heater lamp thermistor falls below 140°C in the standby mode or printing.
When the temperature of main heater lamp thermistor falls below 50°C in the pre-heat mode.
AS POSSIBLE CAUSE:
Main heater lamp thermistor defect
Main heater lamp failure
Main thermostat failure
Control PWB failure
Check the heater lamp blinking with SIM 52.
When the lamp blinks normally:
Check the thermistor and the harness.
Check the MCU PWB thermistor input
circuit.
If lamp lights and stays lit:
Check for disconnection of the heater lamp
and thermostat.
Check the interlock switch.
Check the power circuit and the lamp
control circuit on MCU PWB.
Clear the display of self-diagnostics with
SIM 14.
To clear, enter sim mode:
1) #/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
2) Entering a main code with the 14-key ? START key ON
3) Entering a sub code with the 0-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key
if clear with sim 14-0 doesn't helps, choose sim 52 to check the lamp, or call service!
Sep 13, 2011 | Office Equipment & Supplies
Sharp AR-407 Copier Logo
395 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
