Question about Electrical Supplies
Power Subbly I can't get new batteries for this drill. I need a 6 volt 1.5 or 2 amp power supply that I can put into the handle where the batteries were and run the drill as a cord drill off the 110v ac. If I had a schematic and parts list I could make it myself on a pc board. The drill had five cells in it so its a good size cavity approx 1 3/4 inch square.
    President:
  • 1,922 Answers
Buy a small on board battery charger/maintainer its cheaper and they provide enough current and they do make them in 6 volt models
Posted on Oct 06, 2009
18 volt charger (Dewalt)
The DW9116 is actually a 120 volt charger so it should cope with 130v AC supply, what is the supply from?
It is normal for a standard 110v supply to run at around 117V
See THIS INFO on power supplies
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Whats the voltage maximum on the cobra walkie talkies
Most lithium small radio batteries are 3.6 volts. If AA or AAA batteries, multiply by 1.5 volts. 4 batteries = 1.5 * 4 = 6 volts MAXIMUM. Rechargeable batteries are 1.2 volts. Your charger would be a much higher voltage because it takes power to "push" the charge into a battery. You didn't say, so I am assuming you want to operate the radio with a wall charger. I've done this by soldering the wires to the battery contacts. You need a higher voltage than 3.6 volts, but milliamps is more important. You need enough milli amps to get the radio to transmit. Too much and it frys, literally. So, this is all on you to decide if the risk is worth it. I use a 5-6 volt power supply set on no more than 1 amp (800 ma is my favorite size) 1 amp = 1000 ma. Let us know if this helped!
May 20, 2016 | Cobra FA-CG Micro Talk Walkie Talkies
How do I charge a string of say 10 x 18650 Lithium batteries?
Can get a 4 gang charger on eBay, ~ $20.
If they're wired in series, (nominal 37 volts) will need a DC power supply capable of 40-50 volts DC. Limit the charge current to 1-2 amps with a series resistor or a small 115 volt light bulb..
Feb 12, 2015 | Drills
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
Smart Cycle. Worked Fine yesterday. Changed the batteries, Connections are tight. Turn it on, Nothing No lights on the cycle , nothing on the tv screen.. Other toys work well on the same TV. Help
do you know where you put the cartridge in below where you placed the 4 screws you can take those apart and you will see some cables inside you will see a red and back one together thats the power from the batteries below. i cut mine and drilled a hole on the side where my son wouldnt hit the cable and now my smart cycle doesn't use batteries it uses the power in my house to power it. i used a 4.5 volt 350 mA power supply for some other deal. i had laying around.
you can use 6volt power supply and that will work i wouldnt go higher than 6 volts since 4 D batteries add up to 6 volts 1.5 x 4 = 6 volts. the watts doest really matter since the device will use what it needs.
black cable on power supply goes to red on bike black and white cable on power supply goes to black cable on bike
at least thats how it worked on mine it didnt hurt my bike i had to switch the cables around i didnt have the polarity right the first try.
Aug 27, 2010 | Nintendo Game Boy Advance Console
Trying to power a amp with 16 volts. possible?
Golf carts do not have a charging system. If you are going to use battery power only, why not just add (1) 12V car battery instead of (2) 8V??
MA Audio runs (ran) their bench tests @ 17V. All the power ratings advertized are at 17V.
The power supply for the hk4000D is unregulated. So the more voltage = more power.. 8V-16VDC.
  • RMS Power @ 14.4V
    • 1800W x 1 @ 4 Ohm
    • 3600W x 1 @ 2 Ohm
  • RMS Power @ 17.0V
    • 2000W @ 4 Ohm
    • 4000W @ 2 Ohm
    More input voltage means the amplifier will have to work less hard to make power.
    Don't expect the amplifier to work for very long however. the current drain on a class D amplifier is huge. There are no on-board fuses protecting the power supplies, so be sure to have at lease a 150A power line fuse.
    With 150A current draw - even with the amplifier at 1/2 gain - expect to get 10.6 minutes of listening time from your 16 volts before recharging - also note, the amplifier MUST see 8V to turn on, there is a built-in voltage sensor that will shut down the amplifier if voltage is too low.
  • Jan 23, 2009 | MA Audio HK4000D Car Audio Amplifier
    18v. charger (dewalt)
    I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
    So you could use a transformer (LINK)
    or you could get a local power supply pack.
    Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
    Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
    Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
    Change 120v chager to run on 240v
    all you needs is a step tranformer from 110v to 220v ac
    Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
    Electrical Supplies Logo
    103 people viewed this question
    Top Electrical Supplies Experts
    Steve
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
