Question about Panasonic NN-S540 Microwave Oven
Panasonic inverter model no NN-S540
Can you pls tell me where I replace the light globe in this mcrowave?
  • fossil53 Jul 12, 2008
    Thank you. it is silly that the manual doesn't show you how to replace the bulb!
  • Panasonic Master
  • 9,098 Answers
You can download your owner's manual here.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
  • William Miller
    William Miller Jul 13, 2008
    You're most welcome.
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
I have a panasonic inverter microwave model #nn-S540BFWR. What is the wattage on this model or where can I locate the wattage
The output wattage is 1100 watts. It can be found on the second page of the operating instruction manual. If you don't have one, you can download it at, just enter the model number and get a pdf of the manual. Hope this helps you.
Apr 19, 2011 | Panasonic NN-S540 Microwave Oven
Microwave runs for about 3 seconds and turns off
most likely the thermistor that shuts off the magnetron tube for overheating is defective,if all else is good and there are no hot odors,its mounted on the vent side of the mag
Jul 25, 2010 | Panasonic NN-S540 Microwave Oven
Panasonic inverter model locked. How do I unlock
i have probleam with panasonic inverter model NN-SN977S ON SCREEN H97 NOT MOVING
Jan 28, 2010 | Panasonic Microwave Ovens
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Runs for 3 seconds
check inverter transter or Magnetron short to be repalce
Date: 09.05.2008
May 07, 2008 | Panasonic NN-S540 Microwave Oven
Panasonic NN-S540 Microwave Oven Logo
323 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
