Question about Dell Inspiron 4000 Notebook
Inspiron 4000 power problems
Ac adapter got real hot, eventually it burned up. replaced it but i don't get any power to the machine now. battery is totally drained. and i get no power throught the adapter
    Genius:
  • 2,028 Answers
When power supplies go out, they can cause some real damage to the machine, especially in this case, it being hot indicates a short. First let's talk about the new adapter, if it's a Dell replacement great, if it's a Targus universal not good. The Targus supplies don't work well with Dell machines and can cause problems, return it and get a Dell replacement. If you have a Dell replacement, then try removing the battery and powering it up just with the adapter. Sometimes the adapter going out can cause the battery to develop a short, and this will cause the machine not to start. If the problem still exists at this point, you will need to take it in for a diagnostic, because the problem will be somewhere inside, most likely the motherboard.
Posted on Jul 12, 2008
My dell inspiron 6400 starts when both battery and charger are in circuit
This is more of a remedy then an actual trouble shooting step but mostly works. You would probably hear this from a support agent if they are trying to get you off the phone because this problem make no sense.
Remove the battery and the power adapter from the computer. Then hold down the power button for at least one minute. Then connect every thing back up again and see what happens.
or
Remove the battery and the power adapter from the computer and leave it alone for about 24 hours. Then connect every thing back up again and see what happens.
Dec 19, 2012 | Dell Inspiron 6400 Notebook
Latop will not boot up
1.Ensure your battery is holding power. Some laptops will auto shut-off if the battery won't hold a charge. In that case, replace your battery and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
2.Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. Replace it. Note- high heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power
indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (to touch), then this is not good.
3.Check your power cord. Are there nicks or cuts? If so, unplugg it from the AC power and repair with electrical tape- better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap.
4. Check your laptop lid switch. If it is broken, you may have power but your screen may not come on.
This is usually a little button or mechanism located close to the lid hinge that turns on or off your
screen when your lid is open or closed respectively. Normally the operator does not push this button.
These are fragile and broken easily on some laptop models. Sometimes these can be fixed, more often
they will require replacements. If you aren't an expert repair person, get a technician to
repair/replace it for you. Opening up laptops is a very delicate operation and much more difficult to
repair than desktops. It may be worth it to spend the money for repair.
5. If you have tried these easy solutions and it still won't power on, then your problem lies
elswhere. You may have an internal power switch or voltage regulator problem.. Internal problems will
require professional help.
Nov 02, 2012 | Dell Inspiron 1526 Notebook
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
Dell Inspiron 1420 switch off while on at Internet site and it will not start up again when pressing the on button.
you can first try to connect your laptop to an AC power source via the ac adapter, if it fails to charge the battery, then it must be your battery died. try a relacement dell inspiron 1420 battery,which usually lasts longer and is compatibale with your dell and costs much less than the original one!
May 09, 2011 | Dell Inspiron 1420 Notebook
No power no display
If your laptop won't power on or stay on for long then follow these quick and easy steps to troubleshoot the problem.
  1. Ensure your battery is holding a charge. Some laptops will automatically shut-off if the battery won't hold a charge. In that case, replace your battery with a new one and retry. Check your charging lights or indicators to see if your laptop is getting power and charging.
  2. Check your AC to DC converter (the little black adapter you plug in your AC outlet.) This converts AC power into DC power. Is it abnormally hot? If so, it is probably burned out. You will need to replace it. Note: High heat is not a true indicator of malfunctioning. It can be dead and cold as well. No power indicators on your laptop could be a sign of a dead or bad converter also. Converters WILL get hot (this is normal.) If it is REAL hot (burning hot when you touch it), then this is not good.
  3. Check your power cord. Are there any nicks, cuts or kinks? If so, unplug it from the AC power and repair with electrical tape or better yet, replace it. Many computer salvage stores carry power adapter cords. They're cheap and could save you from electrical shock.
  4. Check your laptop lid switch. If it is broken or not lit, you may have power but your screen may not come on. This is usually a little button located close to the lid hinge that turns on or off your screen when your lid is open or closed respectively. Normally the operator does not push this button. These are fragile and broken easily on some laptop models. Sometimes these can be repaired, more often they will require replacements. If you aren't an expert repair person, get a technician to repair or replace it for you.
  5. If you have tried these easy solutions and it still won't power on, then your problem lies elsewhere. You may have an internal power switch or voltage regulator problem. Internal problems will require professional help so go on down to your local PC store and have a qualified technican take a look.
Mar 04, 2011 | Acer Aspire 4520-5582 Notebook
Dell Inspiron E1505 will power off after 3 seconds
If the system will not run long enough to run diagsnostics, I'd replace the heatsink and the fan
May 14, 2010 | Dell Inspiron E1505 Notebook
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Bad motherboard for M1730
take out the battery of your machine and plug in the power. if it works well, suspected faulty battery. you need to replace it.
May 19, 2009 | Dell Inspiron 6000 Notebook
BATTERY (Li Ion) NOT RECHARGING
in the case of my T23 laptop. when i plug in the ac adapter the battery will charge but when i turn on the power button. It won't boot and will shut off eventually. cant you help me with this
Nov 08, 2008 | IBM ThinkPad T23 2647 Notebook
Dell Inspiron 4000 Notebook Logo
91 people viewed this question
Alun Cox
