Question about Panasonic DMR-ES35VS
Getting set 1 code displayed
No matter what button i press i get "set 1" on display. unable to use the remote. replaced batteries
The code on your remote is mismatched to the unit. Your owner's manual on page 19 will have the cure. In brief, press enter and "1" together for about two seconds. hit enter again and this should fix the problem.
Posted on Jul 27, 2008
Unlocking gateway theft deterrent
go to the dealer
  1. Turn ON the ignition, with the engine OFF.
  2. Turn ON the radio.
Does the radio display LOC?
Is the security code known?
  2. Press and hold the radio preset buttons 2 and 3 for approximately 8 seconds until the first 3 digits of the backup code are displayed on the radio.
  3. Record the displayed code.
  4. Press and hold the AM/FM push button until the second 3 digits are displayed on the radio.
  5. Record the displayed code.
Could you successfully extract the code?
Contact Delco Electronics in order to give them the backup code information and to obtain an unlock code.
Did you complete the action?
Important:: If 8 unsuccessful tries are made to unlock the radio, the display will return to the LOC display, but when the SET button is pressed, INOP will be displayed. This means that the radio must be left powered up for 1 hour with the battery and the ignition applied before any more attempts to unlock the radio can be made. Anytime INOP is displayed, 3 more attempts will be allowed after the 1 hour waiting period with the battery and ignition applied.
  1. Ensure that the code to be used is correct.
  2. Turn ON the ignition, with the engine OFF.
  3. Press the MN button until 000 is displayed.
  4. Press and hold the HR button until the first 2 digits agree with the code.
  5. Press and hold the MN button until the last 2 digits agree with the code.
  6. Press the AM/FM button when the complete code is displayed. If REP appears on the display, repeat this step.
Did you successfully complete the action?
Replace the radio. Refer to Radio Replacement.
Did you complete the replacement?
Operate the system in order to verify the repair.
Did you complete the repair?
Apr 03, 2014 | 2001 Chevrolet S-10
CL flashing even though the coils have been cleaned. unable to reset wine fridge
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
Jan 12, 2014 | Marvel 30WCM Wine Cooler
I changed the batterys in the reciever remote as the system sid batterys where low now I cannot get the remote to respond
Ensure that the batteries are inserted the right way, if they are not the remote will not get power.
Make sure to hit the STB button and then press the POWER button.
Hope this helps!
Mar 07, 2011 | Bell Televison & Video
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
Operating instructions for EM-2R power meter. it has 3 plug-in sender units with remote reader. How do I resynch the senders and reader after replacing battery in reader? Cheers DaveK
I have what appears to be the same device. My instructions list the following method:
1. turn off or disconnect all the remote monitors.
Use the code button on the display module to set the channel. It displays 1 --:-- for channel 1.
Plug in the first remote sensor into the power outlet and press and hold down the SET button until the LED flashes.
The receiver will show numbers where the dashes were in the display.
Change the channel on the receiver to 2 withb the code button, it displays 2 --:--.
Plug in the second remote sensor, press the set button till the LED flashes.
Repeat for channel 3 with the third remote sensor.
This is the same method used to set them up the first time. Having to turn off or unplug the device is the unintuative bit. I assumed it would reconnect after replacing the batteries.
Dec 19, 2010 | Kitchen Appliances - Others
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
UNABLE TO GET PICTURE
dear,
have u checked ur remote.
try to do it if u can with tv buttons.
if it happens with tv button the proble goes to remote.
u can check ur remote by doing a test
just use your camera even mobile camera.
switch on ur camera so that u can see the remote lens (at the top) in the camera and press each button one by one.
even menu button.
if u can see a white light emitting from remote in the camera then its mean that button is working.
check all of them
moreover, if light is seemed dim then change the battery of remote
dont forget to rate, only if it helped/solved the matter
regards
Aug 24, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Please Help!!!!!!!
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Dec 14, 2007 | Car Audio & Video
Panasonic DMR-ES35VS Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
