Cant recieve or output , I bought a new cable and antenna plus a swr meter.
With an antenna connected, volume set to 1/4 from minimum, squelch / RF squelch fully counter-clockwise (or minimum) - do you hear anything from the speaker? If not - plug an earphone / external speaker into the external speaker jack on the rear - any sound? If not, do you see the S/RF meter needle moving (not resting on 0 or 1)? If not - find a channel with activity on as indicated by the S/RF meter first.
Try with another antenna connected if possible, or transmit with another CB radio on the same channel nearby - and try again.
If you aren't able to receive sound (not just static) - or indicated signals on the S/RF meter, the radio *MAY* need to be professionally serviced. Make sure you get an estimate for the work before authorizing - otherwise you may be spending more on a repair than the radio is worth. It is not uncommon to have to pay a diagnostic fee - that most shop will put toward the repair if allowed to do the work.
Radio transmits on PA & U/L SSB.OK....
Will not transmit on AM. just a deadkey with no meter movement. Cannot check SWR or Calibrate due to problem.
Checked all wiring in mic. checked OK
Looked at all connections to board and pots, cannot find anything burnt etc.
Please Advise !
