Question about Tivo Series2 TCD649080 Video Recorder
Tivo & cable
My tivo is acting up. Not sure if the two are connected, but ever since cable started going digital several of the channels that I used to get on Tivo are no longer available. Some of the channels are TLC, VH1 and A&E. Cable says it's a tivo issue and tivo has no solution. Any suggestions?? Thanks.
  • blieber May 11, 2010
    I'm having the same issue...just picked up a new comcast digital adapter, but it won't work...spent over an hour on the phone with the tivo support person and his solutions did not work. I think the digital adapter is your only hope. Let me know if you get it to work
  • flubbard May 11, 2010
    Are you able to view these stations through the TV tuner?
    Scholar:
  • 98 Answers
Have you gone through the automated set-up again, to let the Tivo detect what channels you have and don't have?
I had a similar issue a few years back when Comcast changed our line up, and that solved it for me.
Posted on Mar 26, 2009
How do I set up a tivo series2 to a new digital tv. Do I need analog to digital converter?
Analog to digital converter is for OTA transmission. You are using a cable system, right? If so you have to feed into your Tivo the cable output signal from your cable box and set your tivo to correct rf or video input. Since cable tuner is determining channel all you can do to record is set the channel on your cable unit and program your tivo to turn on and record the input at appropriate time..
Aug 28, 2017 | Tivo Televison & Video
Tivo Premier xl4 won't work right with Charter Cable tuning adapter
You need to have a cable card from Charter inserted into the TiVo, and it'll have to be "paired" with the equipment at the cable company's head end, and on top of that, if they do what's called Switched Digital Video, where some channels have to be specifically asked for every so often to get put on the cable at "some carrier frequency", you need what's called a tuning adapter which is a separate box that connects to the TiVo via a USB cable, and which also connects to the cable company cable (best way is with cable splitter so that one leg "dead ends" at tuning adapter).
First you need to take the tuning adapter out of the system entirely and make sure the cable card is working. Then you can add it back into the mix.
And you may need to harass Charter's customer service department a lot to get this stuff to actually work.
A good place to ask further questions about this is the TiVo Community Forum (which is not an official TiVo, Inc. site), which is where lots and lots of knowledgeable TiVo users hang out and help each other.
http://www.tivocommunity.com/tivo-vb/index.php?
Feb 14, 2014 | Tivo Televison & Video
No video from an Apex digital converter box to TIVO
You may have to set the channel 3/4 switch on the lower right rear of your TiVo to match the output setting of your Apex converter. If your Apex converter is equipped for L/R audio and video output you will get better results using a three-conductor cable to connect to your TiVo.
Dec 08, 2013 | Toshiba DVD Recorder AND Series2 TiVo...
My cable company just went digital. I have a TIVO
you will have to hook the tivo to the cable box and reconfiger, you will have to hook up the ir eye from the tivo to the box so thay can talk. the newist tivo is realy cool it take a cable card and can record muilt chanels but your old one when configured with the cable box will only record one chanel at a time and you wont be able to watch another channel wile its recording
Apr 15, 2010 | Vizio L32 32 in. LCD HDTV
Changing Channels with Series 2 Tivo
Make sure you are using the IR cable to control the Cable Box.
Make sure that you have already done a guided setup again from the tivo box.
Jan 04, 2010 | Tivo Series 2 80-Hours Video Recorder
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
How to connect to digital cable box and TIVO
Click here and start at page 24 to see a diagram on how it should be hooked up.
Sep 23, 2007 | LG 42PC3D 42 in. Plasma Television
Tivo Series2  TCD649080 Video Recorder Logo
87 people viewed this question
Top Tivo Televison & Video Experts
Computer Repairing
Computer Repairing
Dave
Dave
Level 1 Expert
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
