Question about Refrigerators
Frigidaire professional series. Feels cool inside but the air is not circulating and everything is starting to thaw out, ice is melting.
  • DON6253 Dec 29, 2008
    CAME HOME TONIGHT TO SAME PROBLEM.
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
SAME THING HAPPENED TO ME TODAY, WHAT CAN I DO TO FIX THIS PROBLEM? I HAVE A NEW YEARS EVE PARTY WED NIGHT. HELP!!!!!!!!!!!
Posted on Dec 29, 2008
Freezer freezes but at some point thaws and then cools again. So everything is melting then freezing again; ice cubes melt and drip then refreeze.
The auto defrost timer may be broken. The freezer is going for a too long time in the heat cycle. Also ice can be stuck behind the cooling circuit and the cold air is not circulating well. Check if water is going in the evaporating pan at the bottom of the fridge. It should have a little water everyday.
Oct 11, 2016 | Whirlpool Refrigerators
Refrigerator wont cool but freezer does
The problem is the Ice Dam inside your Freezer. You have to defrost the Freezer (making sure to completely dry the Bottom of the Freezer and more importantly the DRAIN TUBE)...
Jul 20, 2014 | Frigidaire FRS6R4E Side by Side...
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer do not work, the light is on in the bottom
I hope the above helps.
Good luck........
Mar 22, 2011 | Frigidaire Refrigerators
Freezer section working properly, 0 degrees, fridge side not cooling enough, 60 degrees. Controls have not been changed.
If it's like mine, cold air from the freezer isn't reaching the fridge section, so you probably have one or both of 2 problems: the circulating fan isn't working and/or the air flow channels are blocked by frost/ice. The fan is probably inside a structure at the back of the freezer that should be removable to check it.
If the fan's running, you have a freeze-up. Solution is to turn everything off, remove food & wait for the ice to melt which will take several hours unless you speed things up with, say, a hand-held hair dryer. This worked for me!
If the fan's not running, you can find a replacement at your local appliance parts dealer.
Nov 04, 2010 | Frigidaire Refrigerators
Icebuildupinsidebottomfreezerdoorwaterleakingoutofdoor
The freezer needs to be defrosted. Take everything out and put it in an icechest with some cold packs, and let the freezer sit open and off to allow the ice to thaw, use a pot or something to take the chunks of ice out and put in. Try not to get your floor too wet, but when too much ice builds up, the cooler cannot cool down the air, and the freezer is only staying cold because the ice is there, but the ice will melt since it has no way to stay cold enough to be below 32 degrees without the cooling unit to keep the temperature low.
Dec 13, 2009 | Frigidaire FRS20ZSG
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire Side by Side model........freezer not working
There is most always an adjustment that diverts part of the cooled air into the refrigerator and a fan to ensure that the air circulates.
This adjustment is generally limited so that the freezer gets the lion's share of cooling.
It sounds as if the circulating fan has failed, or, (very unlikely) the path between the two is somehow blocked.
Jul 19, 2008 | Refrigerators
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
