Question about Miele Touchtronic W1213 Front Load Washer
How to fix a Miele W1213 Touchtronics washer when the intake and drain light is blinking? my drain and intake lights are on.can not use the washer.HELP HUGO
  • 6,487 Answers
Below is how error codes are deciphered by the cycle lights and water level light. This should help diagnose the failure. I recommend to have service technician diagnose and repair your washer.
LONG DRAIN error code will cause the NORMAL, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
If the drain time exceeds 6 minutes, the wash cycle will stop. Push the START/OFF button to reset the mode, a drain task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Drain pump failure.
  • Drain hose: check for proper connection, kinks or clogs.
  • Pressure switch contact failure.
INCORRECT FILL WATER LEVEL error code will cause the HEAVY DUTY, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
Wash cycle stops. Press START/OFF button to enter Standby mode. Execute a Diagnostic Test to drain the water.
POTENTIAL CAUSES:
  • Incorrect electrical connection to pressure switch.
  • Pressure switch is defective.
  • Pressure switch hose is damaged or loose.
  • Air dome is clogged.
  • Drain hose: check for proper height, kinks or clogs.
UNEXPECTED FILL DURING AGITATION OR SOAK error code will cause the HEAVY DUTY, NORMAL, and the HANDWASH cycle lights to to come on and the WATER LEVEL light to blink.
The pressure switch contact selected has opened during agitation task. The wash cycle stops and a Drain task is executed. Once the Drain is complete, the cycle stops.
Push the START/OFF button to reset the operation mode, a Fill task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Water or clothes were removed from basket after Fill task was complete.
  • Drain hose is improperly connected.
  • Water leaking from washer tub.
SLOW FILL error code will cause the HEAVY DUTY,NORMAL, and PERM PRESS cycle lights to come on and the WATER LEVEL light to blink.
If the Fill task exceeds 20 minutes, the wash cycle stops. Push the START/OFF button to reset the operation mode, a Fill task is executed according to previous Wash Temp selection and the previously selected cycle resumes.
POTENTIAL CAUSES:
  • Water inlet valve is clogged or damaged.
  • Water pressure is too low.
  • Water hose is closed/clogged.
  • Water supply faucet(s) turned off.
Hope that helps..........
Posted on Jul 12, 2008
    Genius:
  • 1,665 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE
http://www.repairclinic.com/0088_11_1.asp
Miele dishwasher 892 intake/drain light blinking
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Apr 18, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Used too much soap...miele flooded the floor....drain fault buzzer blinking what do I do?
by using too much detergent the float for water leaks inside the unit would have lifted and triggered the light to light. to clear the fault have some towels around the front of the unit on the floor and gently tip the unit forward and allow the water to escape. the float will drop down and you will be able to use the machine again.
any remaining water in the unit will just dry up. no damage would be done it happens all the time.
May 02, 2010 | Miele Touchtronic W1213 Front Load Washer
W1213 Touchtronics intake and drain light is blinking
Foam has probably got into the logic board, and a new board is probably needed. Sorry !
Feb 02, 2018 | Miele Touchtronic W1213 Front Load Washer
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
How to fix a Miele W1213 Touchtronics washer when the intake and drain light is blinking? power for drain motor is only 20V drain motor not working,but I am tested with 220V end is o.k.
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Jul 06, 2008 | Miele Novotronic Premier 500 Front Load...
Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Miele Touchtronic W1213 Front Load Washer Logo
1,904 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
