Question about Sager NP-5620-C Notebook
Sager 5600d notebook computer not work
I plug the AC adaptor power and battery led on yellow
when push on bottom power led display green and hdd led on after 2 minute stop no beep and lcd no display
after 2 minute cpu fan start very hot and automatic adjust the speed
  • futions Aug 26, 2008
    Sager Model 5600D will not power on at all. DEAD!
    I've replaced the battery. Optained a new Power charger & cord. Checked all connections. Voltage to the laptop, but it is still completely dead.
  • stuartpo Nov 18, 2008
    I have the exact same problem with mine - I suspect the motherboard and/or processor is dead on mine - Sager has the motherboard available for only $400.00 - well on the way to a new laptop. Let me know if you find out anything about yours.
  • 70 Answers
Good observation. this may be ram fault. for proper solution over internet u have to be a techanician.
Posted on Aug 23, 2009
Boots up to black screen ,no battery intalled
It is unfortunate that the computer just has a black screen. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs being displayed on the computer?
    Also let me know if you are trying to just run the computer with a AC Adaptor and without the battery.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 16, 2014 | Dell Inspiron 1525 Notebook
Gateway NV5207u will not power on when the power button is pressed. The Power light does not light up when the battery or AC power is plugged in. Can you help?
Sounds like there is a serious fault in the motherboard. I'm assuming you checked that the AC adaptor is working ok? Check first that there is power to the adaptor and power out of the adaptor by ensuring the green led is on and not flashing, a flashing led indicates power is not making a circuit in the motherboard and therefore a faulty powerboard.
Mar 27, 2011 | Gateway NV5207u Notebook
Hi a philips x51 laptop help - almost dead apart from a few leds
Are you on battery mode?
If you are in battery mode, remove your laptop battery, plug in the adaptor to the laptop (without the battery) and plug to the power outlet. Turn on your laptop.
May 21, 2010 | Twinhead SlimNote N12PI Notebook PC
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
Jun 23, 2009 | Compaq Armada 7400 Notebook
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Where is the ram located in a Sager 5600D Laptop?
I don't know where it exactly is but I can help by saying what it looks like... I recently got a Toshiba Satellite A135 and had them put in a RAM, it's under your computer in one of those unscrewable pieces, it basically looks like a card in there, don't change it unless you know how.
Jan 29, 2009 | Sager NP-5620-C Notebook
Led blinking
Hi, this sound that the AC adapter produces owes to itself to which the same one does not produce the sufficient amperage to feed the equipment, that is to say is damage, they must replace it, if once replaced the problem of which the equipment does not power on Battery must try to power on the same one without the battery pack.
Jul 02, 2008 | Toshiba Satellite A15-S129 Notebook
Sager NP-5620-C Notebook Logo
588 people viewed this question
Top Sager Computers & Internet Experts
David Payne
David Payne
Are you a Sager Computer and Internet Expert? Answer questions, earn points and help others
