Question about Canon CanoScan D660U Flatbed Scanner
Canon Scanner
How do you clean the underneath the glass on the scanner .Regards Roy .
  • 3 more comments
  • no1royboy Jul 12, 2008
    for some reaon I am unable to donwload the mauel it doe start to download but it can not find the the file on the server .I am using the download Manager Programe with windows XP
    Sorry I have just tried to download again and it is telling me thatit cannot find the file Regarfds no1royboy
  • no1royboy Jul 13, 2008
    Hi latoof, that would be great .Thanks no1 royboy
    Hi Latoof . Sorry it is rni91093@bigpond.net.au Regards Roy
  • no1royboy Jul 14, 2008
    Thanks go to Latoof for being very helpful and persitant Regards no1royboy.
Scanners can be taken apart to be cleaned:  'You want to clean the inside?' 'Well, its dirty ikayak, thats why.' Ok take it apart, remember the screw sequences; that aint hard normally for scanners.
Put it this way there aint any little brushes or nanobots to clean it for you in there... you gotta do it manually. Use something alcohol based to lose smears and actual residue. It its dust then use a hairdryer and a soft SOFT brush that doesn't have any dust on it itself... you'll just make it worse.
I hope your scans are clearer now!
Posted on Nov 15, 2008
How to replace a broken scanner glass canon dr1210c
I don't know how the CANON DR 1210-C is assembled but I had an Artec and unscrewing it I could take off the glass.
Oct 12, 2014 | Canon DR-1210C Scanner
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
Scanner produces streaks
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Jun 29, 2010 | Canon DR-2050C Path-Through Scanner
HOW TO CLEAN THE IN SIDE OF THE GLASS OF CANON 3200F SCANNER
Clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Feb 28, 2010 | Canon CanoScan 3200F Flatbed Scanner
Cleaning the Scanner
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jan 19, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Clean glass on MP830?
Best left alone this one, even printer technicians dont remove glass on the scanner unit they just replace the whole scanner assembly, the reason? there are a lot of plastic clips holding it together and springs and cables that are easily dislodged,
often the improvement in scan quality isn't as great as one would think.
the scanner assembly can be replaced as a unit for around $200
May 31, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
How do you clean the INSIDE of the scanner GLASS???
The service manual is avalable free through Emule:
ed2k://|file|Canon%20PIXMA%20MP750%20MP780%20service%20manual.pdf|1416152|F054D74C11BE5EEAF2F6D203362303DE|/
Dec 19, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon CanoScan D660U Flatbed Scanner Logo
429 people viewed this question
old marine
old marine
Corne Viljoen
