Question about Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Unable to locate and load drivers???
So I am away from home for about a month in the middle of no where with one computer in the house. So I brought along my laptop and my wireless router. Now I didn't bring the disk, so I am using the easy installment on the Belkin website to put the router on the home computer. But whenever I click to install it, and it scans for network connection, a pop up comes up and says "Error: Unable to locate and load drivers."
How can I fix it?
  • DakotaV Jul 12, 2008
    Could you break it down for me? I tried what you said and it didn't quite work. I am awfully bad at trying to computer net connections.
  • Anonymous May 04, 2009
    error: unable to locate and load drivers
I had the same "locate and load" problem with my router, i went to my browser to set things up... and eventually I've noticed that NOT CONNECTED turned into CONNECTED, but I'm not sure what I did, because of crappy windows (you have to reset a few times to see that something really changes!) ...but still, I can't use the net, and I'm typing this from the computer on the same LAN, but that uses Ubuntu OS!!! I recommend that you "try Ubuntu, without a change to your computer", the option that you get when inserting Ubuntu 7+ in your CD-ROM...;)
Posted on Jun 07, 2010
  • 550 Answers
Http://192.168.2.1
to open the routers web interface, use the wizards on the router there is no need to install anything
Posted on Jul 12, 2008
  • AlmostBob
    AlmostBob Jul 12, 2008
    from internet explorer, firefox, safari whatever browser is your comfort zone, enter in the address bar
    http://192.168.2.1
    and press enter or click ok
    that is the default IP address of your router, and will open the router's internal website, a structured menu that will guide you through the settings to secure your router
    each page of the menu has extensive help screens that will explain why you are doing, as well as just tell you what to do.
    the wizards are pretty good
I had the exact same problem - did not have my CD, so downloaded easy installer from the web, but got the error about unable to load drivers.
I tried 192.168.2.1 but it did not work - at least not at first. After a couple of minutes I realized the wireless light on my router turned on, so I hooked up the ethernet cable from the router to my computer.
I tried 192.168.2.1 a couple times, and finally it connected and I was able to reconfigure the router.
Posted on Jul 20, 2008
With 30K monthly salary, I am planning to buy a house in Chandigarh with the help of a home loan. Is it a good decision?
It depends on which locality the house is located. Have a look at this: https://www.makaan.com/price-trends/property-rates-for-buy-in-chandigarh
Oct 16, 2017 | The Computers & Internet
Unable to connect sony hx30v camera with home wifi
The drivers being use may be 32 Bit when 64Bit drivers are required or vis/versa. You need to go with Win 10 version that has all new drivers and security. Review all methods used to connect the wireless devices. Check the device drivers and make certain the updates are there and installed. Check connections, cables etc.
Feb 09, 2018 | Sony Cyber-shot DSC-HX30V 18.2 MP 20x...
Screen went black...rebooted, computer seems to
Remove the battery and disconnect the power adapter for about a minute.
connect only the AC then boot it back up. If you can see the Compaq splash screen and still unable to load Windows, re install OS.
If you could not see the splash screen, too bad it could be a motherboard issue,
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
Windows unable to locate cd drive
you reformat your hard disk and install guienuine microsoft window xp your problem will be fix
Oct 26, 2009 | Computers & Internet
Home location by house number shown on GPS is miles from actual location.
sorry there is no solution but i can tell you the problem if you live in europe you won't have this problem but in NA the houses are bigger so the # don't match
May 02, 2009 | Tomtom GO 720 GPS Receiver
1 year old iMac speaker buzzes and sounds distorted
you have to remember that electronics can have interference from wireless signals and etc. try moving your computer to different places in your house
Dec 14, 2008 | Harman Kardon iSub Computer Speakers
Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Mar 24, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
CD/DVD stopped working...device driver unable to be loaded.
Try cleaning the lense / As well install correct driver also; If nothing works out best alternative is to replace the CD/DVD rom with new or working once.
Mar 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Lg 47LB9DF lcd Tv turning itself off whilst channel surfing
Could it be that the mains supply in your area is not steady? It might be dropping unacceptably low for the TV; if you can, get an electrician to at least eliminate this possibility. Rapid fluctuations can occur if there are large inductive loads sharing your line - for instance industrial motors which start and stop with a lot of voltage spikes. These can travel quite a distance, you'd be surprised.
Jan 16, 2008 | Televison & Video
Belkin F5D7230-4 Kit (F5D7230V4SNPDQ) Logo
3,370 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
