LG LDF6810 Built-in Dishwasher Logo
Posted on Jul 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Dishwasher LE error
There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
THANK YOU! THANK YOU! THANK YOU!
Last thing I checked, saved me a bunch of $$$$$$.
Broken grey wire was 1/4 way up the door jammed into the black rubber paint..
  • readytoretir Aug 13, 2008
    not positive of model number, but LG dishwasher is just over 1 year old. Started with LE message today. Unplugging for 2 hours has not helped. Searching for more answers.
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Jul 23, 2008
Anonymous
Expert
Level 2:
Answers
489
Questions
0
Helped
299223
Points
854
When you repair the wires, be sure to wrap the wire harness is plastic like the type you would find in Safeway produce section.  This will keep the wire harness from getting melted on to the black insulation and creating this problem again.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7232
Points
CHECK THE WIRES!!! i spent $250 in parts with no success and finally found a wire buried in the black goo in the door panel. THANK YOU to the guys that steered me to the wires.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
908
Points
First , there is a three wire plug ( blue, sky blue and white) on a controller board. Your ohm meter should read 16.2 ohms between any of those wires. In my case all wires were OK.( Ohm meter checked OK ) , it was a stuck rotor which cased a problem
A
Anonymous
Thanks for solution . In My case it was the red wire,alongside the gray wire.fixed and used electrician tape.
1helpful
2answers
Why is my dishwasher flashing LE
This is very common problem with LG dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem.
Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
My dishwasher is showing LE on the display and will run but doesn't seem to be cleaning the dishes. Any solutions?
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
LE error message
Good Luck!!
3answers
Repair code LE and bottom is flooded
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
LG modèele LDF78105T error code LE
Good Luck!!
There is an error code that says LE
Thanks for using FixYa!!
Jul 27, 2008 • Dishwashers
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
Thanks
Jun 27, 2008 • Dishwashers
3helpful
I am receiving an error code of "LE" on my LG front-load dishwasher...What is it?
just solved a LE error code on my dishwasher,,,,it was a broken wire caused from the black sound deadening material LG uses...apparently when the dishwasher heats up the black stuff becomes soft...wires become imbedded then when it cools and you open the door it breaks wires...easy solution...soldered wire, put a thin piece of plastic to where the wires couldnt get imbedded , put back together and works great
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
19helpful
10answers
LG LDF6810 stops with LE error code
This seems to be a very common problem withe these dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem. I had the same issue with my diswasher (3 months out of warranty). I found out that one of the gray wires which runs the length of the door panel was pinched and broken simply from the repetative motoin of opening and closing the door over time (very poor design). Good news is that it was an easy fix. Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
