Question about Canon Cameras
Memory (ram) is low - Canon Cameras
  • 550 Answers
Generic answers, there is very little that can be accurately done without make and model details
  • get more memory (buy a card)
  • download images to pc and delete from camera memory
  • if using internal memory swap to card memory
  • reduce resolution of images
  • buy another camera just in case
Posted on Jul 12, 2008
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
Memory problems
  • Install more RAM
Mar 08, 2013 | Dell VOSTRO 3350
Can I use DDR400 (PC3200) RAm in my Dell OptiPlex GX260 PC Desktop? Thanks
Yes.
Maximum Total Amount is 2GB.
Maximum Amount for EACH Ram Memory slot is 1GB.
Use unbuffered, low density, Non-ECC.
2.5 volt to 2.6 volt
Chip configuration is 128Meg X 64 for a 1GB ram memory module.
(Ram memory 'stick')
Suggest you watch where you buy it.
Cheap costing ram memory = cheap quality ram memory
Doesn't have to 'break the bank' in cost, but if it's too cheap to be true, it usually is.
Buy from a reputable ram dealer.
Oct 09, 2010 | Dell OptiPlex GX260 PC Desktop
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
We keep getting a memory is low message. How can
You cannot clear about the memory. When it says that, it's referring to the random access memory (RAM) Long explanation short, your computer doesn't have enough RAM. You can purchase a stick of ram from http://newegg.com for about 30-50 dollars.
You need to know what type of ram you have, so ask someone you know that's good with PCs, or get CPU-Z and check yourself.
Dec 16, 2009 | HP LaserJet 2840 All-In-One Printer
RAM compatibilty
No, DDR 400 will not work. The best thing you can do is call Dell and give them your information. Model number and that kind of information and let them tell you what kind of ram you need. If you put the wrong type of ram in your machine it could cause major damage. There are so many different kinds of memory out there, not to mention high and low denisity. Your machine may use PC2700 high density and if you try to use PC2700 low density it will not work. One other thing that you can try is uninstall a stick of your ram and write down everything on the stickers and then go to some place like kingston memory and use their memory locator to find what you need.
Dec 01, 2009 | Dell Dimension 2400 PC Desktop
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
What Does it Mean If It say your Computer In low memory
Low on memory means the actual system RAM is over utilized. If your system has say 512 Mb Ram and you have XP operating system with some applications like MS Word and Outlook open and playing a game at the same time, these applications all take a chunk out of the RAM on the system untill it reaches a critical stage and the operating system detects there is not enough free RAM left to be able to run safely or efficiently and then warns you with the message "Insufficient Memory or Your system is running dangerously low"
Either Upgrade your system RAM or try and not run too many memory intensive applications at one time.
Aug 11, 2009 | Acer Aspire 5720-6661 Notebook PC
Low virtual memory problem
your computer has used up its physical memory (RAM) and is currently utilizing and eating up hard drive space. A computer designates a certain amout of "FAKE" or wat they call virtual memory from the hard drive and when that is taken up it shows low virtual memory. Simply put this just means you need to increase the amount of ram on the computer :)
Mar 22, 2009 | Dell Dimension 2400 PC Desktop
My laptop keeps coming up with low memory!
Low memory usually refers to the RAM. Low space refers to the Hard Drive. You might have too many applications/programs running at the same time on your laptop. Or have an application or program that is using up too much memory. Viruses/Spyware sometimes do this to put your computer in a state that is not usable.
So what you can do is add more RAM. And check your "Task Manager" for applications and/or programs that is using too much RAM. Look under the column "Mem Usage"
Aug 17, 2008 | Toshiba Satellite A70-S249 Notebook
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
