Question about Whirlpool Duet GHW9150P Front Load Washer
Water backs up into washing machine after washing a load.
After washing a load of clothes, removing them and placing them in the dryer, the washing machine fills up with water. The washer contains no water after washing the load of clothes and then slowly fills back up with water. Just wondering what is causing this to happen.
  • Anonymous Jul 13, 2008
    if I don't wash for a few days, my washer fills with water by itself. I noticed it is leaking from the inlet or spout. I have a Duet front load washer. It only started doing that a few months ago. I've had the unit for almost 3 years. I have tried different cycles and it does it on any cycle. Can that part be replaced?
  • Anonymous Mar 30, 2014
    after reinstalling in new place did not fills water
    Genius:
  • 1,122 Answers
Check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Posted on Jul 12, 2008
Water going in 2 the machine after the load is finished and the clothes r taken out
bad water inlet valve or control board? foes it do it even after u unplug it? if so then its ur water inlet valve if it stops after unplugging it its ur control board
water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-5.jpg ALSO CHECK THE WATER PRESSURE SWITCH BELOW
May 27, 2015 | Tricity Bendix AW1000W Front Load Washer
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Hoover washer dryer - not sure it is filling with enough water
How old is the machine and which wash cycle are you selecting? Newer machines use very little water; it is not needed.
Mar 08, 2014 | Dryers
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Excessive lint on washed clothes
Your washer does not have a lint filter, so it's very important to sort lint givers from the lint takers. Washers today to not have lint filters because we rely on the dryer to remove lint that does not get pump out with the wash water.
Below are tips taken directly out of the user's manual:
  • Did you sort properly? Sort lint givers (towels, chenille) from lint takers (corduroy, synthetics). Also sort by color.
  • Did you overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely. Lint or powdered detergent can be trapped in the load if overloaded. Wash smaller loads.
  • Did you select the correct water level? The water level should be correct for the load size. The load should be under water.
  • Did you use enough detergent? Follow manufacturer's directions. Use enough detergent to hold the lint in the water.
  • Did you line dry your clothing? If so, you can expect some lint on the clothing. The air movement and tumbling of a dryer removes lint from the load.
  • Was paper or tissue left in the pockets?
  • Is your water colder than 60°F (15.6°C)? Wash water colder than 60°F (15.6°C) may not completely dissolve the detergent.
  • Did you use the proper cycle time and agitation speed for the load? Reducing wash time (duration) and agitation speed are ways to reduce lint.
Jan 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
EVERYTHING WORKS FINE UNTILL IT GET TOWARDS THE END OF SPIN CYCLE THEN IT STARTS VIBRATING AND WALKING ACROSS THE FLOOR PLEASE HELP ? WE HAVE ALWAYS HAD THIS PROBLEM EVEN AFTER LOWES INSTALLED THE WASHER...
First, make sure the 4 shipping bolts have been removed, and that the machine is level front to back and left to right BOTH! Some machines prefer to be high in the front. VERY IMPORTANT Must have a minimum of clothes & towels, sheets or blankets to wash. DON"T wash 2-5 item loads (small loads)
run machine at least 2/3 full of dry clothes. These machines are built to wash more per load, also because of the many technical parts of the machine, sensors and relays, the machine decides how much water to use not the user! Some "Old Schoolers" have a real issue with the lack of water and unclean clothing... most complaints are user error. Enjoy the new front loading technologies! Cheers! Happy Washing.
Oct 16, 2010 | Maytag MAH8700AWM Neptune Front Load...
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal De
