Question about Dell Computers & Internet
DELL COMPUTER WOUN'T START
COMPUTER WOUN'T START AFTER DELL POWER SUPPLY REPLACEMENT
    Problem Solver:
  • 7 Answers
Is you are getting a flashing amber, check the back or front of the system for diagnostic led's if you do not get any then we are going to have to troubleshoot the actual system. Check also so see if you se any flee power(light on the motherboard). First shut off the system and remove the power cord, then press in the power button for about 2-3 seconds to drain any remaining power. Next remove the power and data cables form the hard drive, also unplug everything from the outside of the system including monitor, speakers, mouse, keyboard. Turn on the system and see if the amber ligth is still flashing and if you have an power led's, the power led's are either a (1,2,3,4 or an A,B,C,D). If you are still getting the flashing amber remove the memory, and reseat(unplug and plug back the power connectors 20-22 pin connector and the 4 pin processory power connector), also unplug the chasis fan connect and then check for the flashing amber light. If you are still getting the flashing amber light the you want to replace the power supply. Now depending on the system some optiplex's have strange power supply's that are not the standard box like design. In that case you probably would want to contact the spare parts department from dell 1-800-357-3355
Small Business, Corporate, Government, and Education & Healthcare
Mon.-Fri.
7am - 8pm CST
Home & Home Office
Mon.-Fri.
7am - 9pm CST
Sat. & Sun.
8am - 6pm CST
or if you have a MT chassis you will probably have a regular box type power supply which you can probably find a replacement on line at newegg.com for around $16 for a cheap power supply 300W, and up forn nicer power supplies.
Now if you still don't like my troubleshooting steps you can got to the website (http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&treeid=3D170450481B7790E040A68F5B2871BC) and select your system type and then you can go through the troubleshooting steps.
**If you system in still in warranty you can just call and we(dell technichans) will just go through the exact same steps as mentioned above with you and more than likely will be looking at a power supply. There are few cases that sometimes the motherboard has gone bad, but that is usually if we get the flashing amber light to change while troubleshooting.
-Your friend Unnamed Canadian Tech Support Agent
Posted on May 14, 2009
    Habit-Forming:
  • 131 Answers
1. Ensure that the power supply is working
2. If yes then make sure all connections are properly connected
3. If No,you will need to buy a new one
Posted on Jul 16, 2008
Have a dell tower and want to know how to fix the fan
buy a replacement power supply fan
or
buy a replacement power supply - dearer option but power supply may be faulty if fan is not running and you fix two problems however be careful with AC input voltage that it matched the power point voltage. or smoke and broken power supply ! take old power supply to computer shop to ensure correct power supply is purchased.
or
if it is the cpu fan
buy a replacement cpu fan and thermal paste.
Possible cheaper options if fan choked full of dust
get a can of compressed air and blow the dust out of the power supply and cpu fans outside your dwelling not inside your your office/ home.
Power supply fan may need a drop of machine oil if noisy or its bearings are worn out..
Oct 26, 2016 | Dell Computers & Internet
Power supply shorted will not start with new power supply
How do you know that it shorted? Where did it short? Is this an OEM DELL replacement power supply?
Feb 01, 2013 | Dell Latitude D400 Notebook
Will not start
smor4u,
There is no reset or fuse to reset. You may need to get replacement power supply. If the computer is plugged into a power strip or surge protector you can bypass it and plug the system directly into a wall outlet and power up.
Power Supply Light-on the back of the computer.
The light is a Green Light by the power supply.
Power Supply light is lit by a signal in the power supply called Power_Good (PG).
If the Power Supply Light Led is not light up, the power supply is defective.
If you need to replace the power supply you can contact the Dell Spare Parts Department at 1-877-717-3355bsat4ube4gblqiaaaaasuvork5cyii= or click the link below.
Dell Spare Parts
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 15, 2013 | Dell Vostro 420 Desktop Computer
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
Feb 15, 2011 | Dell Inspiron 1721 Notebook
My Dell Dimension 2350 won't power on. I've checked cables, power strip, reconnected cable to a known working outlet, and looked under the hood for a breaker. Any other suggestions?
There are four diagnostic lights on the back of the unit. This linke will provide you with what they mean. http://support.dell.com/support/edocs/SYSTEMS/dim2350/advanced.htm#1218079
If all four lights are off, your power supply has most likely died (or the internal fuse is blown). It depends on how far into the computer you are willing to dive. To check the fuse, you'll need to remove the power supply and then remove the cover from the power supply. The fuse will be on the main PCB board inside the power supply. If the fuse is blown, try replacing it (it may blow again). If it blows again after replacing, then the power supply will need replacement. If the fuse is not blown, the power supply is still the likely problem and will need replacement. Be advised that Dell power supplies are special made for Dell cases, so you'll need to be sure that the replacement you get is for your computer or you will have to do some case modifications to get it to fit.
Dec 21, 2010 | Dell Computers & Internet
My dell dimension computer won't turn on. When I push in the button, it only flashes orange and then won't turn on.
Plug the computer into a power strip that has an on/off switch. Turn the power strip on. Press the computer power on button to start as normal, but after after one second turn off the power strip switch just long enough for the fans on the computer to slow down, but the amber computer led doesn't turn off and then turn the power strip switch back on. Computer should start and run fine. Computer typically can be shut down for up to 5 minutes and restarted normally--any longer and you have to sue the power strip power switch routine again
Oct 25, 2010 | Computers & Internet
Cannot start my dell inspiron 570 desk top computer with the power button in front of computer
cannot start my dell inspiron 570 desk top computer with the power button in front of computer
Sep 16, 2010 | Dell POWER SUPPLY Power Supply
New replacement power supply makes continuous high-pitch sound
If the computer turns and works (other than the noise) then the wiring is correct. The ATX plug should be keyed so it is almost impossible to hook up incorrectly, and the wiring is for the most part standardized. However, there could be a problem if it is an older computer and your replacement power supply is from a Dell. Dell ATX power supplies, mostly from the PII to PIII era were not wired to the standard ATX pinouts. So, if you put a non-Dell power supply in an older Dell, or if you put an older Dell power supply in a non-Dell PC of any age, your wiring will not be correct. Usually incorrect wiring means either it fries or just doesn't start at all.
Specialized PC's or high end servers may also use non standard power connectors.
If you paid less than $40.00 for the power supply, the problem is most likely just a bad / poorly made power supply. Most of the budget power supplies are extremely cheaply made. They will sometimes have a lot of noise/whine/hum, and often fail quickly. In a lot of cases you will be able to tell the quality of the power supply just by the weight. The cheap ones are usually as light as can be. A good power supply will have some heft to it, as it will have large heatsinks and heavy duty components. If you have a Radio Shack nearby you could pick up a Thermaltake 300 to 450 watt power supply and try it and see if the problem goes away. They have a pretty flexible return policy. If you have a high quality power supply, it could be that you just got a bad one. Try another to confirm. If you try a Thermaltake and it still whines (and never made noise before this problem came up) then it could be that other components in the PC are near failure--possible as a result of your previously failing power supply. My experience though has been that unless the power supply popped (as in literally blew out) the motherboard and other internals aren't usually affected.
I am assuming here that the computer is starting up. If not, make sure that that all the necessary power leads are hooked up. Newer motherboards may have have a 20 or 24 pin main ATX power connector. They may also have a secondary 4-pin 12v connector to power the CPU. If you are mixing a really old or new revision power supply with an opposite age motherboard there may be a problem of not having the appropriate connections available.
Finally, if you are under-powered, you could also experience problems. What is the wattage of your new power supply and what type of computer/CPU? If you are running a 200 watt power supply to power a modern motherboard/CPU you may not be able to supply the power needed. This could result in a stressed power supply, which may make noise, or just power offs or system instability.
I very much recommend spending the extra dollars for a well made power supply. I have replaced many of the $20.00 units. Even if they say they are 350 or 450+ watts, they don't hold up. Often the computer will start random power offs and then the supply will fail completely. A good supply will usually come with a 5 year warranty and will be generally problem free.
Here is a link to a wiring diagram for the ATX plug--just to be complete.
http://pinouts.ru/Power/atxpower_pinout.shtml
Oct 03, 2009 | Computers & Internet
Computer has shut down and can not re-start
The Dell 8300 does not use industry standard parts. You need Dell specific parts in order to replace the fan. Here is a link to a replacement fan shroud assembly for your Dimension: http://www.discountelectronics.com/index.php?l=product_detail&p=845
You may be able to find cheaper if you do a Goggle search and dig deeper. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Dell Dimension 8300 PC Desktop
Computers & Internet Logo
310 people viewed this question
Alun Cox
