Question about Dometic Rooftop RV Air Conditioner
Rv air conditioning
I have a fifth wheel prowler 93 model it has a Dometic unit in it. this unit was working fine last summer all the way .Now that it is summer agin and hot I try the air will not work at all. I have thought to replace the thermostat. I orderd a (Duo Therm by dometic). Now here is where it starts getting tricky. The thermostat I removed has wires coming out the back that are different colors the the ones coming out of the wall . They just **** connected them together and pushed them in the hole in the wall and screwed the thermostat over top of it. Now this duo therm thermostat i just bought has no wires sticking out the back of it at all, just screw ports for wires . The one thing that bothers me most is what wire to use. Is this factory job or a nut heads job . I did bye the fifth wheel used. And my second question would be if this thermostat is properly installed and still no solution then what! Mind you (I have checked to see that there is indeed power going to the unit, it has power both to the thermostat and the unit on top ).
  • 1 more comment
  • Dwaine Morris Jul 13, 2008
    well there is 6 wires white orange red green grey and a light blue looking wire . now this is the wires that r coming out of the old termostat.
  • Anonymous Aug 18, 2008
    THERMOMETER WON't wORk
  • James Helmer
    James Helmer May 11, 2010
    Thermostat wires are normally color coded. How many wires do you have and what color are they?
  • Dometic Master
  • 6,674 Answers
You may have to remove your filter & look for a model # of your unit, so we can pinpoint your wiring to the thermostat. Usually the terminals on the thermostats are labeled -RC-RH- etc, and you simply move old to new of the same. A lot of times some manufacturers will use phone cable form AC unit to thermostat, and mix up the colors, that's the reason for going to the AC and see what color is used from there. It could be red from control box, connected to green wire to thermostat for example. Thats where you note it and wire accordingly.(terminal calling for red wire, would now be green) If your stumped, get back to us with that model#.
Posted on Aug 16, 2008
Is this a thermostat problem or system failure?
it sounds like no communication from stat to board. cable connections
Jun 03, 2014 | Dometic Rooftop RV Air Conditioner
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
What are the procedures to employ to prevent problems from arising;=preventative maintenance??i have a dometic 15k ducted a.c on a 1997 airstream fifth wheel.
keep the unit clean of debri and dirt in condensing coil . to accomplish this a water hose will work in most cases remove the cover from atop the unit an gently spray the coil take care not to get water into the ducting system and into your coach.Dont do this with unit running disconnect power and dont put unit back into service until dry good luck
Jun 18, 2010 | Dometic Rooftop RV Air Conditioner
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Fifth wheel A/C PROB
Most probably your unit has no more refrigerant charge. Being unused for 8 yrs will cause leaks on seals.Locate for the system sight glass, run your a/c,if you don't notice any bubbles nor liquid appear on the sight glass your unit runs out of refrigerant.Hope some of this information helps you.
Sep 11, 2008 | Dometic Rooftop RV Air Conditioner
Ac and heater wont work
Do you hear any clicking at all ( up near AC or down near furnace, when you move the thermostat ? Have you checked you breakers & fuses in the trailer?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
Rv domatic a/c and heater
Need to know what your air conditioner make & model is. Are you running air conditioner & furnace off same thermostat, or are they on separate ones?
Jul 26, 2008 | Dometic Rooftop RV Air Conditioner
Possible bad capasitor, or seized motor
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
664 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
