Loewe Articos 55 55" Rear Projection Television Logo
Posted on Jul 12, 2008
Replacement part.. can somebody tell me where or who I can call to find out cost and availability of a "color wheel" for this model of TV?.
  • 1 more comment
  • hectec44 Jul 12, 2008
    if some fellow tech somewhere within the 50 States has the answer please send it to [email protected]. See, we service all makes and models of rear projection TV's LCD, Plasma DLP. And this is the first time we run into this make and model of unit which we know is of german manufacture. Thanks.
    We are A Plus Big Screen Inc. in South Florida.
    By the way if we can help with any technical problem on any make, format and model, just send us an Email.
  • kpdc9 Jul 30, 2008
    I too would like the steps for cleaning the light engine I have mine out and am a bit over whelmed. My TV made a very loud worring noise then stopped working as it was giving a negative effect on dark parts of movies and the noise has been there since I got mine earlier this year I decided to pull it apart and try to fix it but now I have the light engine out and am a little lost on getting apart.
  • kpdc9 Jul 31, 2008
    Sorry forgot to ad a way to get the info [email protected] thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jul 29, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
8078
Points
15
Coloyr wheel comes as part of the light engine, I have sent you details on how to dismantle and clean. Usually does the trick. It's a 10 meg file so hopefully it will get to you.
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
Samsung HLP 5063W
Hi it sounds like the problem is with the convergenge ics these can be replaced but the problem usually comes from a bad resistor this causing the ic to go.
The only problem is without having the proper testing equipment in front of you you could keep guessing and never find the problem the best thing to do is if you dont have the equipment nor the knowledge of diagnosing the problem it is best left to somebody who know what they are looking for.
I see this problem often on these sites and it all comes down to the convergence ic failing they usuall fail to a resistor failing on the main board the board will need testing and tracing back from the ics to eliminate any resistors that could have failed.
I have seen alot of people that have replaced the ics without checking the resistors and then they have the same problem shortly after.
The resistors tend to start failing shortly after the warranty has run out.
The cheapest sollution would be for you to take the tell yourself to repair shop as calling somebody out might charge for the call out and for transporting the tell.
Their isnt much you can do yourself but if you need it i can get the spec sheet for you so you can follow circuit diagrammes let me know what you want to do
I need to replace the color wheel in my Toshiba DLP46HM95, and am looking for instructions.
Try website like YouTube.com type in ur tv model and make will have somebody doing a colors wheel replacement and have tutoring video for u to follow.
1helpful
Toshiba 52hm95 dlp needs color wheel. is it true that color wheel is no longer available as standalne part and entire liight engine has to be purchased? anyone know the approx cost of this part and source...
No it is not true that color wheels for this model aren't sold as stand alone you can find one on E-bay.The color wheel is approx $259.59 US.sorry don't know of a cheap place to install.Hope this helps you and have a nice day. loveindeath.jpg
The TV is making a grinding sound. Picture is still fine. What could be the problem?
You have Color Wheel Failure. Light engine must be removed to access and replace the color wheel.
This page shows Samsung Color Wheel part number for different TV Models. This page shows Color Wheel Replacement service cost in Canada.
[email protected]
1helpful
3answers
I understand I need a new color wheel for our HLN5065W TV. I can get the color wheel easy from Samsung but, can you tell me how to install it without a technician? Can I install it myself? Can you tell...
U have some technical skills and machanicals skills?If you don't,u better just hire a tv Tech. to do the job or will end up costing u more money,because the tv Tech. don't like to be hire to fix people mistakes and blunders.Go to You Tube video type in Samsung colors wheel replacement.U will have a tutoring video by some one taking out the colors wheel and replacing it.
2answers
Buy a cheaper color wheel !
Sorry, the color wheel is only available in the Light Engine Assembly. You can not purchase it as a single part. You will have to purchase the engine and replace it to repair your TV. PN: 23405476 it runs about $450 with a $200 core. You may find it cheaper... I don't think it is readily available... Best of luck to you, I hope this was helpful.
2helpful
2answers
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
1helpful
2answers
1helpful
2answers
Loud high pitch humming noise over powering sound from TV
Yes you can repair this your self it is the color wheel also keep in mind that if set does not play after replacing color wheel and lamp lights,color wheel working with all 3 fans running and set shuts off within 30secs of turn on BAD LIGHT ENGINE!!!!!!!! also they are NO LONGER Available cost of that part was 1,000.00
Top Loewe Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
paul fairbanks
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
