Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Phillips tv 32pf77320A/37
Hooked to FIOS, lost picture intermittently became green lines. sometimes when I turned off tv for a while the picture would return. I decided to reinstall with the automatic program. the automatic program finds no digital or analog channels now. no channels recognized. black screen. what can i do>?
  • donnacooney Aug 10, 2008
    I have 2 yr old phillips flat screen 42pf9630a/37 I loose picture and get half picture also sound where do I get this problem fixed?
Problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Posted on Jul 31, 2008
TOSHIBA 36AF42
Your Fios box seems to be faulty
Mar 29, 2008 | Toshiba 36AF42 36" TV
When laptop turned on the screen is bright white with black lines
Hook a spare monitor to the video output usually on the back, if picture okay! you may have a loose video cable, or intermittent LCD display. If spare is the same, it means the video graphic card is defective and is part of the motherboard.
Mar 05, 2012 | HP Computers & Internet
I do not have a remote for the tv but I am hooked up to fios cable system which has its own remote. All things seem to function but I can't change input. All I get when I hit the input button on fios...
The Fios remote work only on the Fios box only as u found that out.U want to control the tv itself,u must have the tv original remote as u used as for like the tv Input button and the tv and other functions of the tv itself.Try website like Remotes.com to buy the tv original remote.
May 09, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
My LG Plasma 42PC3D turns on and off repeatedly. I turn on my FIOS set top box first and than the TV and it turns on and off repeatedly (front bottom display goes red and green, red and green repeatedly)....
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Sep 24, 2010 | LG 42PC3D 42 in. Plasma Television
I can't get a picture or sound. It's brand new
Ur other tv work with the Fios signal?If yes,ur tv have problems,brand new tv call for warrenty service or return it where u buy it for the replacement.
Mar 13, 2010 | Sansui HDLCD-3212 32 in. LCD TV
I have a 50 inch Pro Scan Projection TV that was bought in 1995. I was just watching tv yesterday, everything was fine. All of a sudden when I changed the channel the picture became blurry like it had a...
If this set is a PTK169 chassis, you could have bad tuning capacitors in the horizontal for the Horizontal yoke return and pincushion circuit. I would suggest that only a professional diagnose and repair it due to the circuit it is.
Hope this helps,
Skyassoc
Jun 20, 2009 | Televison & Video
My Polaroid remote control won't work.
First we need to know if the remote is working. Heres the "secret" way to check a remote. Use a cell phone w/camera.
  • Set the cell phone to camera
  • while watching the camera screen and a known good remote, aim the remote at the lens and press a button (volume works well) on the remote (not a device button ie; sat,tv,vcr,etc). You should see lights turn on/flash. Now you know your camera can detect IR light.
  • Do the same again with the remote in question. If there is no IR light output, the remote is the problem. replace the batteries, ensure good battery contact, retest the remote.
If the remote is working then the problem is in the unit.
Let me know what you find.
Neat trick, huh? Please take the time to rate this.
clarkco
Feb 10, 2009 | Polaroid 1720-7 Remote Control
I have recently purchased a Samsung PS50P91FD 50 Inch Plasma Tv. The problem is every now and then while watching tv or playing the xbox the picture is lost and a either the screen goes green or orange...
If this set is still within the warranty period, return it for warranty service. Since this is an intermittant problem, I would request an exchange. If they won't exchange the set (even after going up the chain of management), provide specifics about the problem. State up front that this is an intermittant problem. Once reported, the warranty kicks in even if the problem doesn't become hard and fast until after the warranty has expired since the initial report occurred before the warranty expiration. This is not a problem caused by external devices.
Dan
Apr 16, 2008 | Televison & Video
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Televison & Video Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
