Question about HP Officejet Pro L7580 All-In-One InkJet Printer
HP L7580 just went blank ??
This morning I was printing things on my HP L7580, an hour later I went back to print something else .. The screen was blank. i checked all the plugs, nothing happened. I have owned this printer for 6 months. Any suggestions, or clues as to what happened ?
  • 1 more comment
  • lmnopies Jul 12, 2008
    I will try to re connect the power cords. As of now it shows no signs of life.
    The on / off switch is a "push button" no specific ON / off side. In the past it has been rather difficult to turn off, but usually turns ON easily.
  • lmnopies Jul 16, 2008
    thank you,
    I unplugged all of the cords again, waited then plugged back in.
    It came back on!!
    thanks
  • timsyete Jul 17, 2008
    i think its the power adaptor, if it has one, got same prob with my HP psc 1317
    Sergeant:
  • 287 Answers
Does it make any noises or signs of life if you cycle the power?
Is this unit mains powered or does it run from the USB cable only?
If USB only try another USB port on your PC
If mains powered, check the outlet still has power, the cable is plugged into the back of printer. Some printers have a clip out PSU (usually a rectangular box that the mains cable goes into) push it in firmly as it may be loose (you may be able to clip it out and re seat it completely - ensure mains is OFF first). Check the on/off switch is in the correct position, try powering up when not connected to the PC.
Post back results so I may try and assist further.
Posted on Jul 12, 2008
  • Dave Jul 12, 2008
    check covers/trays etc are all seated properly as there may be an interlock but TBH that seems unlikely.
    You may have to warranty RMA it since its quite new
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
The following printhead has a problem black yellow k y
I have brand new print head and saids that there is a problem with the printer head and will not print nothing the black will not go to the print head need code to over ride and print something in black and white I've tried to shut it down and restarted for 30 sec. and for 15 min's did not work keeps coming up that there's a problem with the printer head model #C8187A-013 serial # MY76553H2 series Officejet Pro L7580 All-in-One email: robertcforce@gmail.com
Nov 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have an HP Officejet 6300 all in one. The printer will disconnect and connect all on its own. I can have just printed something and try to print a second page and it will have disconnected. However, it...
Try resetting the printer using following steps:
1. When your printer is on, unplug the wire that goes to the computer.
2. Presee and release (#) and (*) buttons.
ou will see your display say "Support Menu"
3. Scrolls to the right until you see "resets" and pess ok
4. Select "semi-full reset" and hit OK
5. After printer turns off, turn it back on 30 seconds later.
Jun 01, 2017 | HP OfficeJet 6210 All-In-One InkJet...
HP officejet Pro L7580 print head is not working properly.
i order the 8 jan 2010 2 print heads No : 88 (ref hp c9381a for black/yellow and ref hp c9382a for magenta/cyan) and i receive it after 4 days.
Jun 09, 2009 | Epson CX8400 All-In-One InkJet Printer
Prints blank lines
You either have a cartridge leaking, or what we use to call "whiskers". Sometimes the paper dust and ink will cause there to be hairs hanging under the ink cartridge that drag on the paper. If this is your problem, the only way I know to clean it is to remove the cartridge and get a damp Qtip and clean out under the cartridge carrier.
Mar 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Print preview shows up blank and blue!!??
it seems that graphic card drivers gone bad... check it
Oct 22, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7580 Printer Head Problem??
I had the same problem plus had problems with message indicating "alignment failed" and to monitor the blakc/yellow print head.  The print quality was very bad in black.  It seemed to print about 1.5 lines and then skip a line. When I replaced black and yellow it seemed to get better print quality was just as bad.  Finally called HP support. These are the steps they told me to do.
1. disconnect power
2. remove all ink cartridges
3. remove and clean contacts of both print heads
4. perform simultaneously the following press 6 and # on the keypad while at the same time plug in the power.
5.  --- the printer came on (black squares on the screen) and then shut off.
6. --- was told to power up the printer
7. Printer began checking device(took a long time)
8. Printer began aligning printer (took a long time)
9. Finally finished = Message on screen "Alignment Failed"
10. Still not printing and hours later.
11. They will be replacing printer
12. Then they hit you with that you should buy a set of inkjet cartidges from them at $109.96 -  warranty 2yr, works better, etc.
13. Sent to somebody else to arrange shipping new printer.
14. Free shipping 5-7 days - big deal -  placed my work (home office) on hold.
16.  Service help - listen when it follows the script, otherwise like talking to a door  (In India).
17. Finally get transfered to somebody else and he informs me that he is not authorize to give me a new printer, need to talk to somebody else who is not there.  Advises to call during business hours.  He said that he could request that I be called back but that it could take a 1.5 days to get back to me.
18. I am going to call tomorrow morning during business hours - wish me luck.
I don't know what is awaiting but IN The Future I will not talk to anybody from INDIA - they do not have authority and do not listen (but maybe they don't listen because they can't do anything about it).
Good Luck!!
Oct 03, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
71 people viewed this question
Ben Johnson
