Question about Dishwashers
Dishlex Global 310 dishwasher fills then stops with flashing "fast" light
    Genius:
  • 3,422 Answers
HI,
1)Unplug it for 30min and then plug it back on.After this go for a fast cycle.See if this helps to clear the error.
2)You cant try turning the tap on faster.I believe it is not getting enough water.
3)If you still face the problem then you will have to replace the electronic valve (the thing the hose goes into) which requires a physical presence of a tech.
Please don't forget to rate or accept the solution.
Goodluck..
Posted on Jul 13, 2008
  • 6,487 Answers
Try this one:
turn it off at the wall
turn it on
press and hold the start and program buttons at the same time until it beeps
Hope that helps.......
    Scholar:
  • 148 Answers
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
Dishwasher stops part way through cycle
Sorry I have taken along time to reply but I lost my email access for awhile.Now the fault with your dishwasher is its taking too long to drain.Please reply if you still require help.Once again sorry for not getting back to you sooner.
May 27, 2010 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Dishlex Global 300 - stopping mid cycle
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Mar 19, 2008 | Dishwashers
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
318 people viewed this question
Top Dishwashers Experts
