Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer No nothing is stuck in the pump.Now when I try it there is no noise coming from the timer and there is no noise at all.I put on rinse cycle and that works and it still fills up but when iput it on spin cycle it doesnt work and it still doesnt agitate.Could it be the timer?Thank- you and thank-you very much for the help.
    Novelist:
  • 177 Answers
Check the lid switch first, make sure when you close the lid the switch is activated with the tab on the lid, if the switch doesnt work, your machine will only fill and wait for the lid switch to be satisified. You should hear the lid switch lick or snap when you open and close the lid.
Start here, if could be the motor or timer, however check lid switch first.
Posted on Jul 12, 2008
Water won't drain from tub.how to change pump.everything else works fine. nothing pluged.
Does water drain when washer goes from wash to rinse or is it just at the end after rinse. It could be a switch on the cycle timer not working if it doesn't pump out at all. If it doesn't pump out at only the end maybe one of the cams on the timer that makes the switch to dump water is loose or broke.
Dec 30, 2014 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Kenmore washer not draining/also getting stuck doing nothing
i had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Mar 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
50 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
