Question about HP Pavilion ze4300 Notebook
Won't turn on
Light on front lip would blink a couple times when trying to power up after a couple of attempts, it won't blink anymore. tried another ac adapter, no go.  i've read the comments that say likely  power plug.  is this so?  next steps to confirm?
thanks.
  • Tom Hamilton Aug 06, 2008
    The yellow light on the front flashes, but when powering, it just flashes all the blue lights briefly but does not come on. If power is held down, it flashes the blue lights about once per second. I tried removing battery (not charging up) and it does the same thing.
  • Tom Hamilton May 11, 2010
    Even with all disconnected, still "pulsing". I noticed an SMD transformer visible with 4 leads (under a heat sink) that looks overheated and is making the noise. Also, the resistance across the filter capacitors is about 11 Ohms. Is this too low?
    Problem Solver:
  • 25 Answers
Check the 19 volts port at the back.try to wiggle it with a pointed object.if it moves,maybe it's the problem.u.
Posted on Aug 27, 2008
  • 1 more comment
  • gilbert mangonon Aug 27, 2008
    to tetec,open the lcd.disconnect the power supply of the high voltage module located at the lower part of the lcd.maybe it's 5 wires or 4.and try reboot.u
  • gilbert mangonon Aug 30, 2008
    from where are you?i repaired a unit just like what your describing.and the trouble is just right there.send me a photo.gayugzki@yahoo.com.ph
    maybe you just disconnected the white and the pink wires.try disconnect the connectors of the lcd going to the mother board.11 ohms is too low.try to reverse the test probes.if still,use smd rework station to troubleshoot.u
Help me, dish network hd monitor,model 34-310. made in 2004. wont turn on,on button blinks and attempts to,turn on but screen remains blank. tries three times and blinks a green light. no picture,no sound....
It is the right age for failure---IF you are able look inside at the power supply for bad caps---I will attach photos of what to look for.
The three tries is what is called a three strikes and you are out (no joke)----the unit has built into it (many do) a feature where it will try 3 times to make it up and on and if fails shuts down or stops trying.
Dec 07, 2012 | Computers & Internet
Dell latitude D600 problem
plz repair or reload the operating system
Jun 30, 2008 | Dell Latitude D600 Notebook
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
I try to switch the TV on (either using Power button on the remote control unit on TV itself), but the TV switches itself off immediately. I tried it many times, quickly in succession, as well as after...
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
MAKE A COMMENT HERE and I will help.
SD TECH
Sep 18, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Tv wont turn on< red power light just keeps blinking?
I have the same thing. Just started blinking 10 times. Pretty much had to unplug the unit over night. Could never turn it off and then turn it on again.
This worked for about a week. This morning, tried to turn it on after being unplugged. Still blinks.
Called Panasonic. they attempted a couple solutions, nothing. Suggested authorized repair shop.
Aug 20, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Se-d1 will not boot
escient music server...light blinking red...
cant turn on system...
tried resetting...nothing
tried turning system off..for a hour or two...nothing..
juse blinks will not respond to anything...
any ideas.
Jun 28, 2008 | Digital Products Escient SE-D1 FireBall...
HP Pavilion ze4300 Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
