To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551" If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
error code u052 is a print head error that means the print head is faulty If unit is still under warranty should cover the printhead. Go ahead and call canon support number for your region or go online to canon website for closest Authorized Service Facility and they will take care of it for you. Good luck
The error code is saying you have a fuser fault
Try resetting the machine
get into service mode
then COPIER
then FUNCTION
then CLEAR
then ERROR
then OK at the bottom right hand corner
if you dont know how to get into service mode
call me 00447764303923.
