Question about Philips 47PFL7432D/37 TV
No signal i am trying to hook up my playstation 3 to my 47" philips tv. the problem is, when i push the input button, all AV 1, 2, and 3 and HDMI and Side Input say "No Signal". what is the problem and how can i fix it?
  • djbowler22 Jul 12, 2008
    thank you...but i don't understand why it is saying "no video signal" on all inputs. the red, yellow, and white are all hooked up correctly. i don't know if it's the PS3 or the TV. any info will be taken and tried.
  • 96 Answers
You need to find which is the right channel. It is usually AV2. However make sure you plugged in all the cables to right places. Also, call your cable company and ask them which channel might be, since this new HD tv are so different.
One more thing, If you have a VCR/DVD connected to the TV, you need to check the channel of the VCR/DVD
Artgirlny
Posted on Jul 12, 2008
  • DASEP
    DASEP Jul 12, 2008
    It is saying no video signal because it can not read the playstation. It is not connected properly or you have the wrong source. Try each source one at the time hit INPUT Try Hdm1, then hdm2, then av1, then AV2 and so on. Also, If you have calbe call the sustomer service and they might tell you which is the right source for that specific TV.
    However, it should be the TV on channel03, and the component (hdm3) or AV3. They both should match 3,3.
    Do you have a DVD player connected to the TV. If so, the playstation must be connected to the DVD player, the DVD player must be on channel 3.
    Thank you
    artgirl
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    PS3 hdmi connection works but not std rca AV
    You must set it OFF HDMI while connected to the TV...
    Feb 28, 2010 | Sony Playstation 3 (PS3) Console
    I have a Pioneer reciever that does not have a hdmi input, also There is 1 optical input on it that my cable box is hooked up to. I have not opened the ps3 yet because I'm not sure how to get the sound to...
    ps3 comes with an av jack set as well as hdmi. now you can use the hdmi to the TV and run audio out from the TV to the receiver and that should work but if you don't have audio out on the TV then you need to go get the av cable
    Nov 29, 2009 | Sony Playstation 3 (PS3) Console
    PS3 doesn't connect to tv
    Try holding down the power button for 3-4 seconds when you turn it on.
    This should allow you to reset the AV inputs on the ps3
    Aug 23, 2009 | Sony Playstation 3 (PS3) Console
    HDMI-No signal input
    Turning the power off shouldn't have caused the problem.
    Make sure the TV is set to the correct HDMI (1 or 2) by pressing AV on the remote and moving up and down the list.
    Check the laptop is set to output through the HDMI socket.
    Right click on the desktop -----> properties ----> settings
    Actual options depend on your graphics card.
    Jan 02, 2008 | Philips 42PFL5332D 42 in. LCD Television
    Philips 47PFL7432D/37 TV Logo
    167 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
