Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water Filter Replacement
I installed a new water filter, and the reset button will not reset the water filter. Any ideas?
  • kuna856 Dec 18, 2008
    I replaced LG 5231JA2006A replacement filter and pressed and holded the filter button many times. But the indicator shows 0 and I am not getting water.
    Any idea?
    Kuna
You have to hold the reset button for 3 seconds - not 3 light flashes. I had to experement with pressing the button, you just have to keep trying and counting 3 seconds - mississippi 1, mississippi 2, mississippi 3.
Hope this helps!
Posted on Jul 13, 2008
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
PureSource2 filter popped out on its own. Bought a new one because its past due, but cant get it to install all the way. Tried with & without pushing release button that is functional. HELP!! What is...
These filters, Electrolux advises, have been re-designed. Right now, as of this writing (July 5 2013) they are giving out conflicting reports of whether a special installation technique for the re-designed filter will work (doesn't for me) or if their Service Flash RF1210 will cover replacement of the filter housing (Won't for Sears Kenmore models). I'm unable to solve the problem so have written back to my distributor about this whole problem asking them to dig into it with Electrolux.
Feb 08, 2011 | Frigidaire PureSource2 Water Filter WF2CB
How do i reset the filter light on my refrigerator msd278ge
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    Jul 29, 2010 | Maytag MSD2758GEB Side by Side...
    I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
    Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
    May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
    Changing light after installing new water filter
    Water Filter Status Indicator Light
    (select models)
    The Water Filter Status Indicator Light serves as a
    reminder to replace the water filter. A green light
    indicates that the filter is in good condition. A red light
    indicates the filter should be changed. Once light turns
    red, it will remain red until function is reset.
    To Reset Indicator:
    • Press and hold both the LOCK and WATER
    buttons simultaneously for four seconds. The
    green filter status indicator light will flash
    three times when the function has
    successfully reset.
    Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
    Replacement water filter cartridge indicator light flashing
    HOLD EITHER THE MENU OR OK BUTTON FOR BOUT 10 SECONDS, THIS RESETS IT!
    May 29, 2009 | Whirlpool S20DRSS33 Side by Side...
    The warning light to reset filter came on. I've
    Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
    Step 1:
    Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
    Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
    Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
    GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
    HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
    Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
    Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
    Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
    Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
    Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
    Step 2:
    Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
    Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
    May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    246 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
