Question about Sony PlayStation Portable (PSP) Console
Psp Whats the first step for geting internet on a psp
  • Anonymous Oct 05, 2008
    cant find wlan swich
  • jj0010 Jan 15, 2009
    1001
  • 34 Answers
Turn on the WLAN switch
Posted on Jul 12, 2008
Whats psp pandora
Pandora Radio app exclusive to the PSP. When you have a wifi connection, you can listen to internet radio via Pandora.
Aug 15, 2014 | Sony PlayStation Portable (PSP) Console
How to downloads games PSP-1001 from PC?
Hello
To download games to your PSP You will download your PSP games from the internet into your PC and then transfer your PSP game files to your PSP using a USB cable. After your computer is connected to your PSP, your PC will recognize your PSP as a detachable memory drive (similar to an external hard drive). It will assign your PSP with a drive letter (usually F: ) which will allow you to drag and drop you PSP games file from your computer's hard drive to your PSP memory stick. Below are some of the steps to download PSP games.
Step 1: You must copy your PSP games file to the correct path or the games simply would not work. The correct path is PSP>GAME (all the folder names are in caps)
Step 2: After the PSP games are fully transferred to your memory stick, disconnect the PSP from your PC. In your PSP main menu, scroll to GAME and then select Memory Stick option. Press X, and list of available games in your memory stick will be displayed. If you find any error on your PSP, you might want to check your firmware version.
Good luck
Jan 15, 2011 | Sony PlayStation Portable (PSP) Console
Psp help
Did you know you can use your PSP to pick up free wireless internet? Most people don't even realize this but it's pretty straightforward once you know how! Sit back and relax while you learn to get internet on your PSP!
Requirements:
There are a couple of fundamental things you will need before you can start surfing the web with your PSP. The first is some form of wireless internet source. It doesn't matter where it comes from, could be in your home or in your local Starbucks, all that matters is that you are in an area where you can get internet. Psp wireless settings follow the 802.11b wireless networking protocols, which are just about the most common in the world, so most kinds of wireless network connection will be just fine.
Also note that a copy of Wipeout:Pure is necessary to get internet on your PSP.
Sitting comfortably? Ok, prepare to learn how to get internet on PSP!
Step 1- Switch on the PSP and go to the System Menu, and then enter "Network Settings". From there go into "Infrastructure mode", and select a connection to edit. If you already have a home connection set up or something, just select this as the one you are going to edit. Leave the name of the profile as it is, and skip the WLAN settings if they are already set up.
Step2- Go into "Address Settings" click on "Custom" and be sure to leave "IP Address Setting" as Automatic. Believe me; adjusting this will not help you get internet on your PSP!
Step 3- Go into "DNS Setting" and click on manual. This is where we need to type the address of the web gateway we will be using. The most popular one to use for this is the gateway at Endgadget, so input the numbers "208.42.28.174" as the Primary DNS IP, and put zeros for the Secondary DNS IP. (0.0.0.0). If for any reason this gateway is not working you can usually find others with a quick Google search.
Step 4- In the "Proxy Server" options, select "Do Not Use" All you need to do from there is confirm everything, and save it all by pushing X when prompted.
Step 5- Launch Wipeout:Pure as normal, and go into the Downloads menu. When asked to select a connection, choose the one you have just been editing, and you should be presented with the Endgadget web screen. Et voila! How to get internet on PSP!
Provided you have the resource mentioned above, it's pretty easy to get internet on your PSP. Once you have it all set up you'll probably wonder how you got by without it!
Jul 27, 2010 | Sony PlayStation Portable (PSP) Console
How do i connect my psp to my dsl internet
follow this steps:
Connect your DSL modem to your wireless router. Take an Ethernet cable and connect it from the "Out" port from the DSL modem into the "In" port of the wireless modem. Turn both the modem and router on and let them connect to each other.
Step
Turn on your Sony PSP by sliding the power button up until the PSP screen turns on. Navigate to the "Settings" part of the PSP menu. All of the settings are located on the left side of the PSP menu. At the bottom of the PSP settings menu is an option named "Network Settings." Select that.
Step
Select "Infrastructure Mode" and then "New Connection" from the next screen. Select the "Scan" option and your PSP will look for the nearest wireless connections. Select your router from the list. Your router will be the strongest signal available, and will match the name of the router manufacturer.
Step
Select "Easy" on the next page for the "Address Settings" and save the settings. Press the "X" button to test your connection, and you will connect to the access point. Press the "O" button to exit the settings menu. You are now connected to the Internet with your DSL modem.
Feb 02, 2010 | Sony PSP-3000 Black Console
What are the procedures to download a game from my psp through internet?
In simple terms its this; you will download your games from the internet into you PC and then transfer your game files to your PSP via a USB cable. When your computer is connected to your PSP, your PC will recognize your PSP as a detachable memory (similar to a USB drive). It will assign a drive (usually f: ) and you will be able to drag and drop you PSP games file to your memory stick. These are some of the step to download PSP games.
Step 1
Step 2
This is a simple guide on how to download PSP games from your computer and it is a proven techniques and been done countless of times. Most important of all it allows you to enjoy wide variety of games from other gaming console.
Nov 04, 2009 | Sony PlayStation Portable (PSP) Slim...
I dont know how to dowload java on pSP
This is how you enable JavaScript on the PSP, for use while in the internet browser:
  1. Step 1 Choose "Tools" on the PSP home screen by pressing the "X" button.
  2. Step 2 Choose "Settings."
  3. Step 3 Select "JavaScript" from the "Settings" list.
  4. Step 4 Choose "Enable JavaScript" and then select "Yes." Press the "O" button to close the "Settings" screen and finish the procedure.
There are a couple of ports for running JAVA on the psp, in various stages of development. BlueKVM is one of them, and you can see it here and here. Of course, this is called homebrew programming, and will only run on psp's running custom firmware. Sony does not officially have support for java on the psp.
Oct 07, 2009 | Sony PlayStation Portable (PSP) Console
My psp
the first thing you need to do it update you psp using wifi,go to network update which is the first icon on the psp,it should update to firware 5.0 after the update you will have is including the psp store
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
Im trying to get the internet on my psp but keep geting a dns error code 80410418 can u plz help
You have to know all the internet settings of the connection your are trying to use...
See if this connection are using some security Protocols...
try to folow all the Psp connection wizard and set all the configuration correctly....
Good Luck!
Dec 09, 2008 | Video Game Consoles & Games
Psp
what it doesn't tell you in the instuctions is that you should make a new folder called music in the psp folders window when it pops up showing whats saved on your psp. Make sure you have a decent size duo memory card fitted as this is where the songs will be saved; not on the psp itself. But in your psp settings make sure you have selected USB connection or it wont connect and show anything on your pc.
Sep 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
