Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
How to clean plate glass for Canon image CLASS MF6530?
Copy machine keeps blinking dirty plate glass, but don't know what to do? Can anyone help?
  • Anonymous Sep 12, 2008
    While i am making copies there is a vertical line appears.
  • 100 Answers
SOURCE: printer doesn't put image on paper
The laser shutter is bad or stuck. The new one is redesigned. The shutter could be removed but that would break saftey laws. If its under warranty still have a repair center do it.
Posted on Jun 25, 2009
  • 30 Answers
SOURCE: canon image class mf6530 blank copies
It sounds like a complete print head failure.
try cleaning the printhead with distilled water.re-install the printhead.it most probably fixes you r problem.
if it still doesnt work,
I think you have a clogged or broken purge unit. This is a key component in the printer. It's job is to **** ink out of ink carts down into the printhead and Prime the head so it is ready to print.. No suction, no ink, no print.
Try cleaning both of the ink pads by saturating them with warm/hot water, then close the cover and power it off. Wait 1 minute and turn it back on and repeat the hot water until you can see the pads coming almost white. Now run a Deep cleaning cycle and nothing else. Then open the covers and examine the ink pads. If you don't see fresh ink (Black or colors) then the purge unit did not **** any ink.
if all of this dont work
you ought to call the Canon customer care.
Thankyou
Posted on Aug 07, 2009
shelia_lebea
SOURCE: mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Posted on Oct 21, 2009
  • 242 Answers
SOURCE: canon mf6530 shows "download connected."
you will need a service suport tool to rewrite the software on this machine.
It is necesary to contact a CANON tech to perform this operation, if you try to do it yourself you might damage it more.
Posted on Jun 06, 2011
  • 693 Answers
SOURCE: where can i find a mac scanner driver for canon
You need to download the drivers for your canon on mac Go to this link: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4270#DriversAndSoftware When you get there, select scroll down and select Then where you see "Operating System", select your operating system will then show all the drivers for your operating system scroll down until you see the driver software and then download and reinstall it. Hopefully this will help...good luck.
Posted on Oct 23, 2011
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
Apr 04, 2013 | Canon MF6530 Black and White Copier
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
Our copier says to "clean
When you open the cover you will see two glass plates. the one on the left (smaller one) is for the feeder and the larger on is for an A4 sheet. Look at the small glass plate with a torch (flashlight) and you will see some muck stuck to it. remove it and see how it copies now. Should be clear.
Apr 27, 2011 | Office Equipment & Supplies
When making a copy on our Canon copier (super G3; image class MF4150) we are getting a vertical black line down the entire length of the paper. Is there something we can do to fix it? SG
You can fix this yourself by cleaning the scanner glass. When you insert a document to make a copy it is pulled in and travels over a thin strip of glass. When something gets stuck on this glass it is read or scanned as a solid line. What you need to do is make a copy. Then put that copy in the feeder the same way you put the original document in. Now the line on the copy will "line up" with the area of the glass that has something stuck to it. Use this as a guide to pop open the feeder cover, locate the glass and clean it with a cloth dampened with a bit of glass cleaner. Once you have it cleaned just run a copy again and the line should be gone. Sometimes a small flashlight helps to locate the glass.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Office Equipment & Supplies
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
CANON MF6530 COPIER LEAVING STREAKS
Is this problem appears when you copy from ADF, but not from platen copy glass?-If Yes clean the ADFs copy glass
If the streaks appears horizontal or vertical?
Check the drum unit and/or fixing film
Jan 12, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
My Canon MF6530 keeps flashing "clean platen glass" even though I've cleaned it several times. How do I correct?
You have to take out the glass platten, clean it on both sides.
Then clean the top of the contact sensor (scanner) lightly with alcohol.
Good luck
Oct 21, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Printer doesn't put image on paper
Mar 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
1/4" weak, blurred line from top to bottom of page on every copy...has new drum, cleaned optics and glass, including **** glass...
hi, if the class is clean and the drum is not bad, this means is the fuser unit role cause this problem, but sometimes the cleaning blade too do this when it becomes bad and it doesnot clean the drum well. to help you trouble shoot this problem do this:
open the document feeder donot put any paper on class, and hit start, let the ,machine copy when the feeder is up and no paper, the copy will come black paper, check it if u still see the line there this means the fuser, if not its cleaning blade or drum.
let me know wat happen and if u have pics will help too.
Best Regards
Mar 10, 2009 | Canon imageRUNNER 2000 Copier
Mf6530 always says platen glass dirty but I've even cleaned both sides
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
213 people viewed this question
old marine
old marine
