Question about Sony PlayStation Portable (PSP) Console
The following items are generally required to set up to connect to a network.
Hints
Example of a network configuration
Network equipment connection and setup methods vary depending on the equipment used.
Common settings
You can create network settings for use in connecting to the
Internet through an access point and save them on the PSP™ system. You
can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with
Internet service near the PSP™ system. Settings for the access point
are typically set using a PC. For details, contact the person who set
up or maintains the access point.
2.
Select (Network Settings) under
(Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option
[Automatic]. Select [Automatic] when using an access point that
supports automatic setup. If you follow the on-screen instructions, the
necessary settings will be completed automatically. For information on
access points that support automatic setup, contact your local
retailer.
6.
Select the access point that you want to use.
SSID is an identifier assigned to an access point. If you do not know
the SSID or the SSID is not displayed, contact the person who set up or
7.
Select the type of security that you will use.
The type of security settings required vary depending on the access
point. For details on what type to use, contact the person who set up
8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many
characters you enter as the key. For information on the encryption key,
contact the person who set up or maintains the access point.
9.
Select [Easy].
Basic settings are set automatically.
10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
12.
Save the settings.
13.
Test the connection.
If you select [Test Connection], the system will connect to the selected access point.
14.
Confirm the connection test results.
If the connection is successful, information about the network connection is displayed.
Hints
(Settings) >Psp - in_pspset.gifttp://i.fixya.net/uploads/images/in_pspset.gif" alt="in_pspset.gif" class="h_mi" /> (System Settings) > [System Information].
Posted on Jul 12, 2008
SOURCE: internet in psp
Getting online with your PSP is very simple. First, you must be in
range of a Wifi hotspot (wireless local area network). You can adjust
network setting to connect to an access point such as a Wi-Fi hotspot
or the router on a wireless home network and save the network
connections data on your PSP®. Up to 10 connections can be saved.
Once in range of the hotspot, go to "Settings"
menu, >> "Network" Settings and press "X" Button. Select
"Infrastructure Mode" or "Ad Hoc Mode" and press X Button. Set up the
"New Connection". For details about Infrastructure Mode set up, or Ad
Hoc Mode set up, visit us.playstation.com.. hope this helps.
Posted on Nov 06, 2007
SOURCE: psp internet problem
Ok, this problem has happened to me before, and most commonly the problem relies on a wrong inputed password on your psp. Double check the password you put into the psp is the same one you have for your entire network. If you are continuing to have problems try unplugging the modem and router for about 15 second and connect them again. Good Luck!
Posted on Jan 19, 2008
SOURCE: PSP not support JoikuSpot software?
the PSP only supports WEP. What encryption does Jioku use?
Posted on Jun 03, 2008
SOURCE: psp no connection to internet
It's not the usb... It is a internal error, that can only be fixed by getting a new psp... found in models, psp-1001 and psp-1001k made in north america, i tried everything, but if you have a early psp... get a new one.
Posted on Jul 27, 2008
SOURCE: WPA internet wont work on my psp
The PSP does not support WPA2. It does however support WPA.
Posted on Aug 12, 2009
Feb 14, 2010 | Sony PlayStation Portable (PSP) Console
Feb 07, 2010 | Video Game Consoles & Games
Oct 24, 2009 | Sony PSP-3000 Black Console
Mar 07, 2009 | Activision Shrek the Third for PSP
Feb 02, 2009 | Sony PlayStation Portable (PSP) Slim...
Sep 14, 2008 | Sony PlayStation Portable (PSP) Console
Aug 31, 2008 | Sony PlayStation Portable (PSP) Console
Aug 06, 2008 | Sony PlayStation Portable (PSP) Console
Feb 26, 2008 | Sony PlayStation Portable (PSP) Console
Jan 27, 2008 | Sony PlayStation Portable (PSP) Console
146 people viewed this question
