Question about iLO LCT32HA36 Television
LCT32HA36 TV's Green power light will come on. and it will go in standby when i power it off and green when i power back on. but i get no picture or sound. im a electronics guy myself (computers) iv replaced CAPS before in computer LCD screens. but in this TV i dont know witch ones i can try and replace. would i need to replace the ones on the Power supply board? or on the TV tuner board? theres just so many to go replacing them all. is there a way to test each one with a multimeter?
  • slightlyunpr Jul 12, 2008
    all the caps seem normal. no bulging. no leeking caps. they all look ok. even tho they might not be. whats my next step?
    I have found out that its the inverter. im getting picture useing a flashlight and looking real close to the screen and im also getting sound. the inverter is getting 24V at the plug from the PSU. the inverter on/off switch wire is only getting 4.9V. the cord running power from the LCD Controller board over to the turner board is marked 5V and its getting 4.9V. theres a RED LED light on the tuner board thats not on. heres a few pics.
    kinda lost on what to try next. all my troubleshooting points to the
    inverter board. but that red LED being off has got me thinking it may
    be something else.
    if the inverter is what is bad does anybody know where i could get one of these?
    Power Supply is a MLT169B REV 1.2
    Inverter is a CMO 1320B1-16A
    Tuner Board is a E3761-053020-3 has phillips on the tuner in/out jack box.
    Pic1
    Pic2
  • 2,336 Answers
Check the capaciotors in the power supply for bulging conditions.
Click here to have an idea how they might look like.
Good Luck.
Posted on Jul 12, 2008
  • 1 more comment
  • Jaime Hernandez Jul 12, 2008
    Check this guide on where they are located as well instructions on how to replace them.
    If they all the capacitors look good, measure the voltages with the LCD connected to the AC line and connected to the rest of the circuitry just to see if when current is being drawn from the power supply the voltages drop. Pay attention to the 5VDC and the 24VDC, if those values decrease it means the capacitors are not working properly.
  • Jaime Hernandez Jul 16, 2008
    If everything measures correctly from the power supply to all the circuit boards, chances are that the inverter board is not working.
    I would suggest to check all the solder joints, specially where the inverter transformers are solder, if one of them has a dry or open solder joint; the rest will not work or power up.
    Good Luck.
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Ilo LCT32HA36 won't show a picture but does have power
Hi, I had a computer monitor that acted similar one time and what I found were that there were some bad capacitors in the power supply board inside. They were identified by the swelled up rounded ends and the heat discoloration of them. They look like little aluminum cans with a vinyl sleeve shrunk around them with the component values written on them. A normal one is flat on the end with no signs of any leakage around them of a brownish blackish substance similar to wax or tar. They are relatively inexpensive at an electronics supply store($1-2 each) so I replaced them all. This will require some soldering and electronic repair knowledge though. The power supply could not stabilize so it just kept shutting down the picture that only displayed for a brief instant.
Good Luck!
Jan 24, 2009 | iLO LCT32HA36 Television
ILo tv
It looks like the power supply failed on your TV. If the LED is solid red or green, it could be some leaky or dry capacitors but if the LED is blinking, the failure is more complicated to repair.
I service these power supplies. If you need more info you can send me an email to jah2mil@hotmail.com
Jun 04, 2008 | iLO LCT32HA36 Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
iLO LCT32HA36 Television Logo
873 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
