Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate care II keeps filling flooding the garage. It will not move off the fill position on the little turn dial. we manually move the dial to try to get it to agitate and the only spot it will do anything at is drain and then spin.
    Novelist:
  • 177 Answers
A couple questions.
Does it continue to fill with the timer turned off.
Yes, you have a mixing valve problem
No. You probably have a pressure switch problem,
I would guess its the pressure switch, check to make sure the hose running from the outer tub to the pressure switch has a cut in it and needs to be replaced, or the pressure switch is bad.
If you are uncomfortable trying to find problem call a service tech.
Posted on Jul 12, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not fill all the way. Even when set on super it only fills to small load setting.
hi i can help you. to reset the fill level you have to move the dial all the way to reset, or as high as it will go and then back to what u want.
Jun 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II washer
If it will perform all of the functions if you turn your timer knob manually, I would open the console and check for any loose connections, although from your description your timer motor has gone bad (only availible as the whole timer) It can be purchased from online from the manufacture or from a local parts store.
Jun 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
