Question about Sony PlayStation 2 (PS2) Console
What is nh3 in memory card
What is the nh3 save in memory card
    Scholar:
  • 148 Answers
National hockey 3,its a saved game on your card you can delete it,unless you have that game
Posted on Jul 12, 2008
Hi i loackd my memory card few mnths ago and nw i forgot the password i tried diffrnt paswrds but its stil locked,,,n it gvs option of formating it but i dont want to loose my images vdos n muzik...kindly...
Memory card in a locked condition, the data can be saved. There are two ways you can do:
1. Use the data recovery software (must be software full version). How: insert memory card, run the data recovery process, select the drive memory card, etc. Save the file to your hard drive recovery. After the data saved, memory card format (quick format), then restore the data into the memory card.
2. Quick format memory card, and do the data recovery process. So that data can be saved, do not do a full format, but do a quick format. Tools such as hard drives, flash drives, memory cards, when done quick format, data can be saved.
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    When i click photos it comes(car, phone, dishw as saving failed..it was alright first..its samsung corby..this problem occured just today
    First check whether the phone is configured for saving the photos to memory card or phone memory. In case it is configured for saving the photos on memory card, change it to save in phone memory and then try saving the photos. In case you are still not able to save the photos, you will have to reset the phone to factory defaults. In case you are able to save the photos in phone memory, try the memory card in another phone, if no go then you will have to format the memory card.
    May 18, 2010 | Cell Phones
    I'm playing FFVII on a PS2, and I'll save my game to the memory card, but when I go to load it, there is no data... I tried saving on 2 blocks, but when I did that, the first save had a bunch of glitches...
    a memory card is a memory card at the end of the day and mad catz is virtually just as good as the offical sony stuff. it is the memory card being faulty as it is not actually saving or showing up. try buying a new memory card
    Nov 24, 2009 | Mad Catz 8007 PlayStation 1 Memory Card
    Problem saving ogre battle to the playstation 2
    You can't save Playstation games on a Playstation 2 memory card. You'll need to find a Playstation memory card in order to save your games on your PS2.
    May 17, 2009 | Atlus Ogre Battle for PlayStation 1
    Sonyericson k750i cannot save images
    Hi
    Firstly have you a memory card inserted?
    If yes, is there any problems reading files from it?
    If yes, remove memory card and re insert, it may just be connections dirty?
    If no memory card inserted chances are your camera settings are set to save to memory card.
    To change this start the camera and go to settings/options.
    Look for default save location. If it is set to save to memory card and you dont have one, that would be the reason why it is not saving images. Either install a Pro Duo memory card or change default save location to 'Phone'.
    Hope that helps?
    Apr 27, 2009 | Sony Ericsson K750i Cellular Phone
    Save failed problem on PS2 with guitar hero: world tour
    my brother has a ps2 and a memory card (hint)
    1) check that you have a memory card
    2) check that its in properly
    3) maybe its coruptted
    --full str pka
    Dec 31, 2008 | Sony PlayStation 2 (PS2) Console
    Playstation card
    Your question is somewhat confusing, using a playstation 2 memory card, will have PS2 game saves on it, how would you play PS2 games on a PS1 from the save, you can't. If you just mean you are using a PS2 card for a PS1, the way a PS2 card saves data is different to a PS1 card, so it probably won't work You can use your PS1 memory cards in the PS2. You can only use the PS1 memory cards to save PS1 games that you are playing in your PS2. You can't save any PS2 game data to a PS1 memory card
    Oct 05, 2007 | Sony PlayStation (PS) Console
    Sony PlayStation 2 (PS2) Console Logo
    96 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
