Whirllpool ultimate care II
Whpl ulcr 2 will fill with water and but stops after agitating (ME?}. it will do this on all cycles. what can i do besides use my hammer? The washer fills and agitates in all cycles. after the wash cycle, it dies. will not drain or spin. replaced timer ($$), did not help.
  • Anonymous Nov 10, 2008
    my waher will not drain or spin
  • Toby Norton
    Toby Norton May 11, 2010
    Sounds like you have a lid switch problem. Do you hear a click when you close the lid? If the switch is not pressed, the machine thinks the lid is open and wont continue past a certain point. If it's the easy model, just tightening the 4 hinge screws on the right and left hand sides of your lid should correct the issue. If it's the more complicate "pin" style (you have a pin in the lid that pushes down on a hole in the top of the unit). For that style, you will need to replace the switch. This can be purchased from a local appliance parts retailer or online form the manufacture's web site with your model number (just under the lid in the rear center). Once you get a lid switch, you remove the console screws and swing the console up. You unplug the lid switch (green, white, and gray wires). Next you Remove the brass cabinet clips (push down then away with a large screw driver). Tilt the cabinet forward, remove the 2 phillips screws underneath the lid next to the hole for the pin. There is also a green ground wire on the switch. You unscrew this with a 5/16 nut driver or socket. Reassemble in reverse.
  • 246 Answers
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Posted on Jul 23, 2008
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
You might have a bad lid switch. Are you able too add clothes to washer when it agitates without it stopping? If so check the lid switch.
Jul 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
