Question about Gaggia MDF Coffee Grinder
Can't disasseble burr set
I have had my Gaggia MDF grinder for about 15 years and it has always worked well (use it virtually everyday). Over the last few years I've had the grind setting set to 4 and it became stuck on 4. I can't turn it either way. I managed to fully disassemble the grinder but still can't remove the theaded piece that controls the coarseness of the grind and which would give me access to the burr set. I took the machine to a Gaggia authorized service center here in California and the technician was unable to remove it either and just gave up (!?).
Any suggestions?
  • lfvalente Apr 04, 2009
    I should have posted this before, but I totally forgot. I managed to solve the problem as follows:
    - Got an 8ft long 2x4 (not kidding)
    - Attached to one end a hinge from a large garden/driveway gate. The hinge has two triangular plates with holes to screw them to the gate and the gate post respectivelly. I screwed one end to the 2x4. I sawed off part of the other end so that it would fit just right into the grooves of the upper holder (#13 in the parts diagram you sent).
    - I then secured the grinder on a workbench (a big vice will do but be careful not to damage the housing) and used the 2x4 as a huge lever to turn the upper holder. In my case, it still didn't work and ended up bending the 1/4" thick hinge.
    - I then decided to turn the grinder upside down and immerse it in a solution of cleaning powder used to clean (backflush) espresso machines). Used boiling water and let it sit for about 1 hour, Be careful to only immerse the top holder and not to get any water into the electrical motor.
    - Repeated the previous step and it worked like a charm!
    If any one needs pictures of the 2x4 setup I could take one and send you.
    Novelist:
  • 137 Answers
Take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Posted on Apr 04, 2009
I just disassembled and cleaned my Gaggia coffee grinder. When I turned it on to calibrate the burr plates it made a short grinding sound then stopped and now won't turn on
Take it apart again and check all the connections and switches, security shut-offs, and THE THERMAL SWITCH. A very small and cheap electronic device that takes and overload and will shut your system down, whatever it is. Very easy and quick to replace.
Nov 25, 2014 | Gaggia MDF Electric Burr Grinder
Need operating & maintenance manual for brevetti gaggia mdf burr grinder.
Hello, your instruction manual can be found on this link by clicking or copy and pasteing it to your browser http://www.gaggia.com/dam/bo/allegati/files/31_mdf.pdf if you are unable to obtain these instructions by copy and pasteing to your browser please message me back and I will provide my email so that I may send you them directly.
Thank you
Rick
Nov 08, 2011 | Gaggia MDF Electric Burr Grinder
I have a Gaggia burr grinder, Brevetti Gaggia SA Model MDF, s/n 7262. The handle that you flick back and forth to let the grinds come out broke off inside the unit.fixable? 707=837-8916 Thanks Anne
Look inside the grinder, The lever is attach to a SPRING .
May be the lever is disconnected (unhooked) from the spring.
AND YES IS FIXABLE.
It cost you about $15-$30 for the parts.
Jan 15, 2011 | Gaggia MDF Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
How do you adjust the size of grind with a gaggia grinder
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
Apr 20, 2010 | Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
MDF very coarse grind
Several possibilities loom:
1. Same burrs for 25 years? don't be cheap replace them!
2. Dirt in the threads of the burr carrier, or the threads that recieve it?
Let us know what works
Dec 18, 2007 | Gaggia MDF Electric Burr Grinder
How long should it take gaggia mdf to grind?
I'm not familiar with this exact model but the problem may be either packing in the unit...since it never worked...or that the beans have jammed the unit in such a way that none are feeding to the burr. Usually, there is a way to remove the top half of the burr after removing the beans. Brush out the area and reinstall. The instructions that came with the unit should be of value. By the way, on some of these units, if the cup isn't correctly placed, it may prevent the burr from receiving flow. Enjoy!
Nov 29, 2007 | Gaggia MDF Electric Burr Grinder
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Aug 18, 2007 | Gaggia MDF Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
209 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
