Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Hissing sound All of a sudden, the camera presents a hissing sound when recording.
    Problem Solver:
  • 17 Answers
You can check the monitor audio with earphones if the sound hissing when your recording that means it came from the audio, usually wierd defects cause by bad contact conector.
Posted on Dec 01, 2008
In my Pd 170 Camera. When I Input Line in From Sound System in Live Events.. Audio is Spread. I check my wire and all connectors. what the problem?
Posted on Jun 05, 2010
Poor sound on videos
if hissing noise coming there may be problem with the microphone, open the cam, change the mic.
Dec 14, 2015 | Nikon COOLPIX P5100 Digital Camera
Steering problem
if its a power steering setup with the belt pump setup with fluid then the pump has worn out, harder steering and hissing are common symptoms of a faulty pump
Feb 23, 2014 | 2003 Chevrolet Tahoe
Rpm go down and almost stalls when brake
sounds like you have a vacum leak does it run fine before applying brake? if so you may have a brake booster leaking start the car put your head down under dash by steering column push brake pedal and listen for a hissing sound if present then you brake booster is bad if not have someone apply brake open hood and listen for hissing sound coming from vacum lines you should be able to locate this by sound good luck
Dec 06, 2013 | Hummer Vehicle Parts & Accessories
Camileo s20 hissing sound on video playback
This sound may be the AGC (AUTO GAIN CONTROL) maxing out in a quiet recording situation.
Try again with some closer sound to be recorded.
Feb 04, 2011 | Cameras
Samsung 32" crt tv, hissing sound
You will find that the Flyback assembly or the EHT cap connected to the top of you picture tube is "leaking". The hissing sound is arcing caused by insulation breakdown in the plastic block of the flyback assembly, a faulty tuning capacitor in the horizontal output stages, or if you live in a humid climate, dust that may have accumulated on the back of the tube/high tension stages , will create a track of conductivity when it takes on moisture from the air. The hissing sound is the air being ionised by the high voltages present.
There is in excess of 25,000 volts in these areas, and repairs to your set should be done by a professional with good experience if you are not familiar with the problem I am speaking of, particularly about the rubber cap connected to the tube. Voltages remain present here even after the set has been turned off, and will remain so for an extended period. The picture tube needs to be discharged correctly before any attempts to repair problems here are made.
I am happy to discuss things further if you wish.
regards robotek
Aug 05, 2010 | Televison & Video
Hissing sound when recording
hissing sound when recording is due to old microphones or frequency interuptions if you have a wireless mic i suggest you to find a new mic, or if you have singstar use their mics
if it is video recording then buy a new camcorder
Jul 07, 2009 | Electronics - Others
Hissing sound inside my sansui tv
You have a short on the secondary side of the transformer that is hissing. You are going to need someone knowledgeable in electronics, to help you find the short. Most likely it is your Horizontal output transistor.
Sep 08, 2008 | Sansui Televison & Video
put the camera into manual mode from there get into the menu options and adjust the recording volume level.
May 18, 2008 | JVC GR D370US camcorder Mini DV
I have found that sometimes this can be interference from your line input. If you don't use the hardware that is plugged into it(if any) when recording TV shows, then mute it in your sound card volume settings
Jan 15, 2008 | Genius Soundmaker Value 5.1
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
133 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
