Question about ESQ Watches
My ESQ 5290 watch - the chronograph is missaligned with the 1/10 of a second counter and minute counter. I managed to reallign the second counter. Tried booklet instructions - crown position 2, using b (lower button) for minute counter - nothing happened. Crown position 3 to adjust the 1/10 second counter using same button nothing happens. Watch keeps correct time.
3 Suggested Answers
SOURCE: seiko watch stuck crown
The crown maybe a screwdown type. Try unscrewing (like jar lid)them pulling out the crown.
Posted on May 04, 2007
escapement
  • 2334 Answers
SOURCE: New battery install in my esq e-5290 watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ESQ watch manuals. Rate me, please.
Posted on Mar 05, 2010
TW Steel unable to reset minute chronograph hand (small upper left dial) I know how to reset second hand crown out push upper button etc but how do I rest minute recording hand
If the reset procedure still fails on time and date set crown positions together with chronograph buttons, and the minute counter doesn't move even when the stopwatch runs, the following can be tried:
The minute counter's motor may be stuck. Swipe a magnet hence and forth in different directions close to the back of the watch until the minute counter moves. The other hands may also move, but they can be reset later. Continue swiping several times to loosen the motor. A sheet should be placed behind the back of the watch to avoid scratches. Once the motor is loose enough, it can be further loosened by using its reset button which will spin it around when depressed.
Aug 25, 2011 | Kenneth Cole KC1232 Wrist Watch
I have an ESQ 300385 watch but cannot understnd how to use the various feature in the small windows, AL,Ad,Hl, OF. Help would be appreciated
Go to Chase-Durer.com and download the operation manual for the Fighter Chronograph. It also has the two LED displays and same functions.
Aug 14, 2011 | ESQ 300964 Watch for Men
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
Watch is working fine but the chronograph is not
sounds like it needs to be serviced under warranty. The clutch mechanism maybe jammed or broken.
Apr 26, 2010 | Sector 2653940025 Wrist Watch
Mar 05, 2010 | Watches
How do I reset the second hand on an ESQ E5290 Chronograph watch for the elapsed time function.
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get cheap wow gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service for your login.
Jan 10, 2010 | Watches
The minute counter on my chrono won't reset to zero.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Jul 30, 2009 | Pulsar 100 Meter Alarm Chronograph PF3277
My second hand on my esq bracer chronograph resets to a few seconds before zero...how do i fix it?
Mine did the same. I fixed it. Go here
http://www.esqbymovado.com/pdf/ESQ_Fusion_Instructions.pdf
Jun 06, 2009 | ESQ Swiss Bracer 07301091 Watch for Men
The (second(s) Counter Stick has stopped
is it a chronograph model? If so, reset the chrono. If not, you are going to have to send it in to a repair shop or the mfr to repair it...probably bumped it hard
Aug 14, 2008 | Breitling Hercules 246/GRY/PROF
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Watches Logo
97 people viewed this question
Top ESQ Watches Experts
Bill Boyd
Are you an ESQ Watch Expert? Answer questions, earn points and help others
