Question about Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner
Sanyo STW1223H1 The unit no longer blows cold air, it does not appear that the compressor is kicking on. Repair man could not find a connection to check or add freon. Can this unit be re-charged or is there something else wrong with the unit? Thanks Rick
  • Anonymous Apr 21, 2009
    i have sanyo ptac unit on my room , i nneed thermostat swith, model nos is STW-122341
  • 38 Answers
SOURCE: AC is not blowing cold air. How do I add freon?
What you will be looking for (in your engine compartment) looks almost like a large valve stem that you would see on a tire. It will probably have some kind of plastic cap on it.
It shouldn't be that difficult to find. You may want to search for an engine compartment diagram for your make/model/year vehicle.
Posted on Mar 19, 2009
  • 8 Answers
SOURCE: compressor not turning on
is the compressor actually turning over ?? if not check the contactor, or capacitor is actually ok...
if it does turn over, are the stop valves open ??
Posted on Jun 16, 2009
  • 1114 Answers
SOURCE: trying to add freon to my 99 gmc sierra, as i add
The compressor cutting and out is a good sign that the system is trying to work. Usually when the compressor cuts in and out after a few seconds, it means that the system is not fully charged and more refrigerant is needed. It's a good idea to purchase a gauge that measures the amount of charge in the system. The gauge looks like an air gauge, and they are not very expensive. That way you will know how much more of a charge the system needs. The gauge hooks up to the low pressure valve, just as the charge hose does.
Posted on Jul 02, 2009
professio101
  • 158 Answers
SOURCE: the unit only blows warm air. it just stopped
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Posted on Aug 01, 2009
SOURCE: Car AC stopped blowing cold, compressor turns on, Freon at 45
check the thermo control amp, it is a sensor that keeps the evaporator from freezing. I had that problem on my 2000, it's a common nissan problem, google nissan ac problems.
Posted on Sep 22, 2009
APE08AJM1 - GE 115 Volt Portable Electronic Room Air Conditioner - Compressor not kicking on. Manual indicates it's triggering the overload relay? How do I solve this?
There is a start capacitor near the compressor that may be bad. If the capacitor tests OK then the compressor is locked up. A service man can try to get it going with a kicker capacitor but there is no guarantee that that will work.
Sep 14, 2017 | GE Heating & Cooling
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Why does my unit not blow cold air
No gas or less pumping in compressor. Call service man to check the unit.
Aug 17, 2012 | Samsung AW0505M Air Conditioner
The unit runs fine, but the compressor kicks on for 2 seconds and then shuts off, this just repeats over and over every minute or so. so it never blows cold air.
It could be a capacitor problem; however, more often than not, the compressor will fail to start at all with a failed capacitor. The sytem could be low on refrigerant causing the compressor to overheat and shut down. Another item to check before hiring a tech is to inspect all of your electrical connections and repair/tighten if necessary. Loose connections can cause motors to overheat and shut down.
Because you state "the unit runs fine" I'm assuming the fans are blowing air normally across the evaporator (blowing inside the RV) and normally across the condensor coil (blowing outside). Is this correct? If so, because the refrigerant level will need checked, you will need to have a licensed service tech look at your unit and offer his/her expert opinion of what your best options are.
Without having a toolbox in hand and being onsite to repair your system, I do hope you find this information very helpful to you in items to check yourself. Let me know if you have any further questions. :-)
Mar 13, 2010 | Dometic Rooftop RV Air Conditioner
Goodman unit freezing outside the unit
Its not the thermostat.
The things that can cause this problem are lack of or poor airflow over the Evaporator coil. Or a low system charge. Or quite possibly a restriction in the line on the low side. When they replaced the compressor did they purge the line set with nitrogen and pull a deep vaccum? This is imperative when replacing a condensing unit to ensure that no residual particles are left in the line set to create a restriction.
Hope this helps You
please rate me
Jul 24, 2008 | Goodman CKL60AR60 Air Conditioner
Cooling problem
Since it is not so hot outside you may have to adjust the Thermostat to a lower setting to get the AC unit to kick on the compressor and blow out cold air. Give it a try, and if not the T-stat then we can go from there.
Jul 14, 2008 | Office Equipment & Supplies
Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner Logo
145 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
