Question about Jwin iLuv i7500 Shelf System
Display light is no longer working
About 2 months ago the display light on my Jwin iLiuv7500 started to get dimmer. Over a period of 2 weeks or so it went totally dark. This is the second time this has happened. The first time Jwin sent me a new system under warranty. The second time the warranty had expired.
We have to use a flashlight to try to read the display. Any ideas as to how this can be repaired
  • Hoikey Jul 12, 2008
    How do you go about repalcing the light bulb?
  • 1,512 Answers
Hi, I hav replaced hundreds of LCD backlamps over the years. They can just go dim with tim, you will find the lamp has gone silver as the filament is slowly burned out. They can be easy to change. Taking the lid off to check will tell you if it is easy. Often they just plug into a rubber grommet on the back of the LCD. Other times, they can be mounted to behind the LCD, and changeable only by removing the LCD..
If it blow all the time, I used to modify certain models that this was a problem with a ballast resistor, so 39ohms, 1 watt in line with the lamp to bring the burn time up a bit.
If you try to replace it yourself, find the voltage to the lamp and get a decent quality part to replace the lamp.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 12, 2008
    Champion:
  • 217 Answers
Lights don't necessarily go dim over time before going out. Typically, they either work, or they don't. You may want to check the wire connections providing power to the light, if you can access them. The connections may have come loose from the refrigerator vibrations. If it doesn't seem possible to get in there, then you'll probably want to get a technician to come fix it, to avoid possible damage to any of the system. These units are generally sealed fairly well for protection and quality purposes.
    Sergeant:
    Champion:
  • 417 Answers
Lights burned out need to be replaced
Ten pieces of my jwin portable dvd player has a problem with the display it shows white how can i fox that?
White light means that your LCD display panel is not triggering only the back light of the panel is working. They come from China.
Mar 08, 2011 | Jwin JD-VD502 DVD Player
'04 Sorento, 110,000 mi., shudders faintly when accelerating from a stop. If I take off slowly, no shudder. I drive with 'Snow' on and less shudder. Also, probably unrelated, about 1 month ago I turn...
could be a falling cam sensor or O2 sensor, O2 sensors don't like being cold as it takes longer to heat up and ecu reads it as a fault. cam sensor these fail more when they get hot. dirty MAF/MAP sensor can also affect the engine.
Jul 15, 2017 | 2004 Kia Sorento
TX-DS656 - No display, still works.
Mine goes out sometimes, if I go to the reciever and hit the "Display" butoon, the display lights up dim, at same time, I hit the " Dimmer" botton on remote and display works for about 1-2 weeks. Don't know what is cuasing it, but that got the dispaly to work. Can deal with that I guess.
Sep 02, 2010 | Onkyo TX-DS656 Receiver
A couple of weeks ago the monitor would come on but when the computer started the light would start flashing but monitor would come on after a few minutes,then it slowly started to take longer and...
This failure is caused by a semiconductor (perhaps a IC or Power transistor), as the part is getting worse, the display will taken longer to work. Unfortunately, today displays are getting cheaper and repairs on this kind of issue is not recomended. You may need to consider to get a new one.
Oct 09, 2009 | Hanns.G Corporation Computers & Internet
Airbag and ESP lights on dahboard
my power steering light comes on and off, and the car will not switch on once turned off, its draining the battery??
Mar 16, 2009 | 2002 Volkswagen Golf
Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
Please wait
try to clean loading sensors
Jun 03, 2007 | LG RH-4820 DVD Recorder
Jwin iLuv i7500 Shelf System Logo
242 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
