Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Posted on Jul 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 253.54703405 ice maker does not reset
The ice maker is making ice fine. After a batch of ice is made, the arm does not return completely back to the "ON" position. I have been lifting the arm manually, and letting it drop to reset it. As soon as the arm returns to the "ON" position, the arm slowly raises as it fills with water, and the next batch of ice is made. I have to reset the arm manually after each batch of ice. Is there something I can do without replacing the entire unit?
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Jul 12, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316456
Points
2771
A gear under the cover turns the arm,i think you should find a appliance part store in your area and replace,around $50 for brand new one,thanks-mike
1helpful
Kenmore bottom freezer ice maker not working.
  1. Reset the ice maker: Check the manual that came with your fridge for instructions on how to reset the ice maker. Many refrigerator models have a reset button or switch that can be used to reset the ice maker.
  2. Check the water supply: Be sure the water supply to the refrigerator has not been turned off or become obstructed. If the water supply is turned off or obstructed, the ice maker will not make ice.
  3. Check for obstructions: Make sure there are no obstructions in the ice maker that would prevent it from making ice. If there is something blocking the ice maker, remove it and try again.
  4. Check the ice maker components: check the components of the ice maker such as the water inlet valve, ice mold thermostat or heater. The problem could be with one of these components and replacing them might solve the problem.
If trying these steps doesn't solve the problem, it might be time to replace the ice maker.
Kenmore coldspot 106 ice machine makes one batch and turned off
It could be that the ice maker needs to be replaced and it is broken.
Every time my ice maker dumps a batch of ice, it lifts the arm and turns off the maker.
That sounds to me like it is working exactly as it is supposed to. Once the tray is full, the arm lifts and it stops making ice. Once you use some of the ice, it will drop the arm and turn the ice maker back on.
Ice maker makes one-two batches of ice
Either the arm has something causing it to stick or the actuator switch is mis-alligned or faulty.
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Ice-cream maker doesn't fit together
Do a 1/2 to 2/3 batch. Put a book and a soup can on top of the mixing arm to keep it down.
The machine does make wonderful Ice cream, however it is noisy and fiddly. Do not try the full batch as it just doesn't work. I find doing 2 half size batches works best. Also find a spare room to run the noisy beast in.
Maytag MSD24GR ICE MAKER
you need to turn off the water to it then take the arm and move it all the way down and turn on the water and you should hear it click than give it time for the first batch to get made be adviced to throw the first batch away somtimes there is dirt and little uglies in the first batch good luck!!!!
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
