Question about Eclipse AVN5500 Car DVD Player
Eclipse AVN50D i installed an eclipse AVN50D in my 07' honda civic sedan but the only problem i fouund was that the buttons dont light up, is ther a cable i missed or how do i get them to light up?
  • Spiral04 Aug 12, 2008
    I have the same prob. Did you find a solution?
I found a site that sells nav discs. i am not sure if they work. you might want to check it out.
http://www.deals4biz.com/search/1949897305/eclipse+GPS+%26+Navigation+Software
Posted on Feb 19, 2009
It was a while ago when i installed the unit but if i remember correctly the wiring harness did not have a wire in the place for "illumination", so i just took one of the unused wires and put in that place.
Posted on Oct 04, 2008
  • saadcee Oct 04, 2008
    In 07 honda i believe the illumination wire is red with silver stripe, check if your harness has a mate for this wire, if not add one
I NEED THE NAVIGATION CD TO GET MY IN AVN 5OD TO WRK HOW DO I GET ONE....
Posted on Jul 22, 2008
Maintenance light blinking
First to check with OBD codes reader, this is one advise to fault; when you have this number (code) the clues for solve the problem are more.
Try it, comment and rated this.
Apr 10, 2010 | 2002 Honda Civic
Honda Civic 2007 Civic . Cahange wheel bearing and
sorry to tell you this but it sounds like the wheel bearing was put in backwards on one or both sides. the front wheel bearings have a black speed ring built in and that is what your speed sensor reads off. - this is common as the front bearings will install either way- hope this helps
Dec 12, 2009 | 2007 Honda Civic GX NGV Sedan
Replacing tail lights and brake light component on a honda civic
Most cars tail lights are atached by a couple of nuts from inside the trunk. you will have to peel back the carpet , or remove plastic cover panel if there is one.
May 09, 2009 | 2002 Honda Civic
93 Honda Civic Sedan not shifting into overdrive
overdrive may be worn out and u dont feel it shift or ur tranny is messed up
Jan 13, 2009 | 1993 Honda Civic 4 Door
CEL Error Code p2227
P2227 is thrown for barometric pressure circuit range/performance error. I'm researching what causes it since I have the same thing on my turbocharged Accord.
Aug 26, 2008 | 2007 Honda Civic GX NGV Sedan
1998 honda civic ex sedan
remove rear seat, remove round metal cover, disconnect fuel lines and wires from top of fuel pump, jack up rear of car. remove gas tank straps, lower gas tank with a jack, install is reverse.....if you need to just replace the fuel pump you don't have to remove tank you Can access from under rear seat good luck and please rate -jeff
Jun 11, 2008 | 1998 Honda Civic
Eclipse AVN5500 Car DVD Player Logo
1,410 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
